Tire options
black N boosted
Boosted
Perkasie Pa
Looking to buy a new set of either dr or slicks... I always ran the m&h dr which are 28' with my factory 3.55 recently I swapped to 4.10... Should I stick with the 28' or drop to something shorter? I'm only spinning the motor to 6200rpm... Thanks in advance for the advice!
Where do u cross the traps?
Will you run it past 6200?
How's the car used?
black N boosted
Boosted
Perkasie Pa
How's the car used?
With a 28' and 355 I was hitting the rev limiter in 3rd right before the 1/4
Haven't tracked it yet with the 410 cuz I need a set of tires
I'm not gonna push it past the 6200 cuz is sti I motor still
Cars is a track/ weekend car
Thanks for the info in advance
Stick with 28"
6600 rpm shift points with a voretch, stock long block, for three years, in my 06
bunits19714
monroe , mi
Get the MT et street R's they are a bias ply. when their size is in just numbers ie 28x10.5x15- the metric versions are a radial- that should be all the tire you need with your hp level.
