Really?
I have torn down motors to the short block before and put them back together a few times so I am ok with that. I am paranoid to rebuild a block though. All those clearances and balances and things seemed like I would have to take a lot of time reading and buying new tools just to have the first motor fail and do it all over again within a week.
You know I pulled apart an automatic transmission once.
.......once....LOL
I have a machine shop who I trust to measure bearing clearances. They will also target a clearance for me if I specify. They have much better measuring equipment than I do. I can verify with plastigauge but that's more of a ballpark reading imo. I've used it but don't really trust it.
If I had a machine shop I couldn't trust to do the correct machining then things would be different. I realized some time ago that I can only control so much, precision machining is one of those things I have to pass on to someone with the tools and experience.
IMO it pays to talk to a potential machine shop. I mean really talk to them, not just have them tell you they have been building sbc motors for a long time and lots of racers swear by them. Ask if they can hold the ra for a mod motor, if they say yes then ask if they have a profilometer to measure the ra. Ask them how they determine bearing clearances and why they do it that way.
I called quite a few shops until I found two that would actually talk to me. Most would just say something to the effect of "this is how we do it, we have always done it this way, we know what we are doing". The shops who gave that sort of answer were generally upset that someone would even ask questions.
Of the two who talked to me I chose one who didn't specialize in mod motors but they did a whole lot of modern motors like LS and the new Hemi. Modern motors have some things in common like closer tolerances and mls gaskets. Being able to obtain the closer tolerances with the correct finish is a big deal imo. What I'm after is something that comes out as close to stock clearance and finish as possible. Ford has an excellent track record with the mod motors. For longevity and for ability to take abuse. All I'm doing is replacing the parts that usually fail and maybe bumping the compression, using a ported head, things like that. I'm not specifiying large clearances or re engineering the design. IMO Ford already spent a whole lot of time and money to get the motor where it is.
With all of that said if I was doing something for big power numbers I'd be calling someone who builds racing mod motors that last. There are only a few shops that truly build race motors and it will cost you. Ask Dave about that, lol.
Any thoughts on 12:1 compression on 93 octane pump gas? All the standard pistons I see max out at 11:1. Can I squeeze some more power out of a N/A setup and not have my tuner kill me (or my engine)?
12:1 is all you can get with a Big Bore that's stroked. At least that's all you can get with the FRPP 53cc cnc heads. Stock heads will boost it a little and the 48cc heads will boost it even more. For any more compression you will need chamber casts sent to the piston manufacturer in order to make pop up pistons.
I've run my 12:1 with 92 pump gas. It runs just fine. I keep max spark advance down to 26 degrees. I think it could go 28 just fine but I did pick up spark retard during a wot pull once. It was after I had filled at a station I don't usually use. I really think I got 89 or less octane because I had previously been able to run 28 degrees without issue.
I leave the knock sensors turned on, same with rear o2 sensors, cat and valve protection. I've even run 92 pump with boost and 11 and 12:1. The tune was kept conservative. I'm of the opinion that leaving all the protections on helps the motor to survive should something go wrong.
