Too much traction for stock
Lcfrshadow
I got the car with the wheels and tires already on it. Im going to step down to a 295 tire. Should be more in line with the power of the super. Now I just need to address this clutch. Damn this is getting expensive, fast. Faster than my stock mustang,
Midlife Crises
Fairbanks, Alaska
Clearly you need to replace your clutch. Perfect time to upgrade a bit for the coming step up in torque. I have had good performance from McLeod products so I would recommend there Street kit. Add to it their steel flywheel and throw out bearing and your set for about 500 ftlb. Make sure you get a new, roller type pilot bearing.
MrAwesome987
Upstate SC
I wouldn't waste the time with swapping the rear tire for 295 unless the 305 is worn out (sounds like its not). Mine will melt the 295's I have on the back right now. So if you're planning on a supercharger in the future, keep the 305s.
vxr500
That’s a lot of rear tire for a stock 3 valve. I also have a 2010 track pack with J&M control arms/panhard bar, Koni Orange ST’s all around, and a Boss 302 sway bar on the stock 255s and I can burn the tires at will. Planning to go 285s at most in the rear.
