Torque Specs on clutch install?
Nstaley
I need the exact specs for the torque when installing my new Mach 350 Stage 1 clutch on my 08 GT. Anyone know FOR SURE the exact for the pressure plate and such? It's different everywhere I see.
AutoXRacer
Florida
I would call the manufacturer...
I can get you OEM torque specs...but aftermarket parts you should ask the manufacturer. No instructions included?
saleen07gt
St. Petersburg, Fl
With factory tty bolts for the pressure plate it is 33 ft. lbs. with 60°. I ended up torqueing mine all to 70 ft. lbs.and worked fine.
eighty6gt
TTY???!!!
I wonder if these are actually tty. Even the oil pan bolts had a tq spec and an angle - I figured to crush the gasket???
