BlackGT
I've been dealing with this problem for a while now, and I'm finally tired of the sensor light that goes on because of this problem.
I've never been able to program my left front rim, I'm assuming the sensor is bad, but do I need to purchase the whole band, along with sensor, or simply the sensor? I've never seen them in person, so I'm not sure if they are able to be swapped out without replacing the whole unit.
My other issue is my driver side rear tire. The sensor/band are obviously loose. Now, would this generally mean that the installer did it incorrectly, or has it broken off? I know this might be difficult to answer, but maybe someone that has had the same issue may be able to help me out.
Thanks.
Thanks.
