Track this weekend
matt texass
Well I finally got back to the track after a year. Mods as it sits now were JLT, cmcv deletes, UDP's, Dynatech longtubes and offroad x pipe. TCI streetfighter 3000, spyder shaft, 4:10's, bmr rad support, bmr lca's and uca, sportlines and stock wheels upfront with mt et street 26x 11.5/17's.
The track I ran at is know for times being being questionable. But here are the results
60 foot-1.874
1/8th-8.285
mph-83.54
1/4-12.98
mph-102.986
launched about 2000 rpms. How do I get this 60 down more? Sportlines have my pinion angle all jacked up there is no downward angle with my control arms in the relocation brackets anymore and they are in the 2nd hole and level -is this hurting me?
any other advice for a mid 12?
DirtyDeedsInc
Groesbeck, Texas
Which track did you run at so I know not to pay attention to the time slips? Are you spinning the tires much off the line? If not I'd say to start launching at higher RPMs until you do then back it off. Level LCAs won't hurt hardly any, downward toward the axle will help, downward towards the front will hurt. How much pressure are you running in the tires?
matt texass
Prarie (scary) Hill, not spinning, running the ET streets at about 17 psi at the moment.
DirtyDeedsInc
Groesbeck, Texas
OK, that's where I've been running lately. May get bored and go out there this Sat. I guess I need to go to a real strip to see how far off my times are, just never have time. I'd say try launching harder unless you're spinning or getting wheel hop.
