Stang 23
I have an 05 GT with an automatic transmission. A couple months ago it was slipping from second to third gear but not too bad. It would slip just a bit and then go into gear. I was told to put a shift kit in to help boost up the pressure in the transmission to help it last longer and make the shifts firmer. It was better after this but now whenever i run my a/c as well the tranny starts to do funky things and slips more. I know that a/c causes the engine to work harder but it seems like its having to work a lot harder and the engine has a wining noise when the a/c is on. It also seems like the tranny is working harder too. When i had the car serviced a few months ago i was told that the a/c compressor is slowly going out but it still blows cold air. Could the a/c compressor be putting a lot more drag on the engine and causing the tranny to slip more or would it be something else? Any advice is greatly appreciated.
