WOT
Hi All.
Items is used unless specified.
All items are boxed and ready to go.
Anything else other than Local is extra.
1. Turbonetic complete turbo system for manual transmission 05-09 Mustang GT.
Price is SOLD for local pick up or delivery within the area of Miami or Ft Lauderdale, Anything else other than Local is Plus shipping and PP FEE.
This is not a tuner kit. The system is complete and ready to bolt on with all necessary hardware and its components for it to work.
NOTE* There is a dig on one of the pipes with a few scrapes, This does not affect the turbo system's function and it's a cosmetic blemish.
If you have any question please PM me.
Thanks for looking
• Turbonetics Ceramic Ball Bearing Turbocharger 60mm
• Turbonetics Evolution External Wastegate
• Newer design Front Mount Intercooler
• Bosch By-Pass Valve
• T304 Stainless TIG Welded Exhaust Piping
• Aluminum TIG Welded and polished Intake Piping from turbocharger to intercooler to throttlebody
• Silicon molded hose for connection to the stock airbox
• 8x 39 lb/hr fuel injectors Ford racing Blues
• Fuel Pump Controller, pre-programmed (boost referenced) with harness
• 8x Spark Plugs, Early style, 1 heat range colder than stock Autolite
• 8x Spark Plugs, Late style, 1 heat range colder than stock
Thermostat (used for later style '07-up) GNK
• High flow aftermarket air filter used in a stock configuration K&N or open filter.
• Diablo hand held ECU programmer with pre-loaded Turbonetics CARB legal program
• De-gas resevoir
• Turbine housing and tube wrap heat shielding
• Hardware kits including fasteners, fittings, gaskets, clamps, hoses, and oil lines
http://www.turboneticsinc.com/sites/default/files/60164_revG.pdf
Thanks for looking
• De-gas resevoir
