Valve Cover Breather ?????
jasongt06
After reading countless posts about ways to stop oil from entering the throttle body on the 05+ 4.6 3valve engine would there be any harm in just putting a K&N breather on the driver side valve cover and blocking the port on the throttle body?
I know its your first post, but use the search function!! there are multiple threads will all the info u need for this stuff.
Mick Mach
Front Royal, Va.
Thanks, I think since my 07 GT is bone stock I will put a K&N on both sides.
thats fine but you will get a stinky oil smell in side the car and will see oily residue around the passenger side breather. its not bad but you will smell it and see it.
jasongt06
Thats no good, I guess im going to go with a seperator then.
