06StangGT
Not sure if this would technically count as tech so I posted here...
With the new engine in I wanted to add a catch can. I was told that I would not want to use the typical pcv breathers so all of that was removed. I knew going in that the material of the covers was just a shit cast of whatever Ford had laying around at the time. I had two local reputable shops attempt to weld the holes closed after removing the vct all together. They also welded two -10an bungs I've had these shops weld things in the past for me and have come out perfect.
These looked like hell when I got them back but after how long it took this build to complete and with as many obstacles I encountered along the way, I wanted to get the thing running so I slapped them on last spring. They were fine for the majority of the season. Only put about 700 miles on it altogether and I noticed the weld on the driver's side vct hole was starting to leak.
I don't really want to use these covers anymore, and I have another unmolested set at home I'd like to try to use. I need the -10an bungs welded on, and the pcv/vct holes closed.
Short of buying the $700 Moroso covers that have the holes pre-closed, does anybody have any ideas of where I can send my clean set out to have the same thing done?
