VCT lockout questions,mechanical and tune.
TheKurgan
Florida Keys
the VCT limits your valve spring\camshaft options. once you get to stiffer springs it starts screwing with the VCT since the cam timing is adjusted and sustained by oil pressure. too much spring pressure and the phaser doesn't have enough oil pressure to hold steady cam timing. if you're running high lift cams then you can't afford to have unstable cam timing...the stock phasers allow for up to 60 degrees of retard so if that happened at 7500rpms in my engine it's toast.
anyway you'll gain way more power by using aggressive cams+springs than by playing with a couple degrees of cam retard\advance. plus it's added protection.
i don't have any more info on the V10 gears but i think blow by racing actually sells them. i may be wrong about that but i know we have a vendor here that uses them in some of their builds. that info wasn't out when i built my engine or i most definitely would have used them.
I think you run N/A iirc. I'm sure it's important to get every last bit of HP out of an N/A motor, but if boosted guys want more power they just up the boost. There's not really a need for huge cams and the looming danger of valve to piston contact. Just sayin...
Edit: This doesn't apply to All-Outers lol. Most people are happy with 500-600HP daily drivers. :thumb2:
Marc s
NASA AIX
Auburn, WA
I compared my dyno graphs from January and the ones from last night after the lockouts were installed. The HP curve is identical up until about 6,000 RPM's. Then the curve with the lockouts starts to fall off. The lockouts cost me about 20whp at the peak. I would rather sacrifice the power and not run the risk of failure.
