Vibration at 1500-2000 RPM
99horsey
The prothane mounts themselves are going to transmit more vibrations, thats the price you pay for stiffer engine mounts.
This is true and I would guess if I went back to the factory mounts I wouldn't be able to feel the vibration anymore. That treats the symptom but not the disease. The vibration is severe enough that I'm more concerned with finding the cause and fixing it than comfort.
Since not all people who put new mounts on have this same vibration, I have to think it's not just the nature of the beast. I hope not anyway and am still going to try to find the root cause.
99horsey
After my new clutch was installed yesterday I can confirm that my vibration had nothing to do with the clutch. No change. I might still try a new harmonic balancer, but I have very little faith that will solve the problem. Since others are seeing the same vibration at the same RPM, I'm wondering if this is just a somewhat common internal balancing issue due to tolerances that since the mushy OE mounts cover up, it escaped the factory...
itsslow
My automatic vert coyote kind of had the same thing but only at stop lights, if you had your had on the shifter you could feel the vibration. The cats were hitting the transmission, previous owner did a shitty job installing them. Honestly, I think your issue has something to do with the exhaust, motor mounts, or harmonic balancer.
99horsey
The exhaust has been off twice in the last month and both times I looked at the mounts, etc. The first time, the midpipe hangers were bottoming out on the brackets, so I followed the TSB to correct that issue with no change. There is no rattle, just a vibration like something rotating rotating is not balanced. It feels like it's coming from the engine. I really don't think it could be the exhaust. The motor mounts are transferring the vibration to the car but I don't know how they could be a source of vibration. This leads me to think harmonic balancer or internal balancing is slightly off.
Based on the other similar reports, it still seems possible that engine manufacturing tolerances allow for imbalances that the mushy OE motor mounts cover up, but that are revealed with stiffer mounts.
Victoria, BC Canada
Digging up this old thread. I have this issue, but even worse. Car was smooth as silk until it was in a crash. Passenger side floor board hit a barrier, not a high speed crash. Now there is severe vibration. DRIVELINE IS NOT THE ISSUE, it is the engine or a grounding problem. New motor mounts on order. Factory harmonic ballancer seem to be fine. New flywheel and clutch installed after crash to try and solve vibration, it did nothing.
Starts around 2200 RPM and feels like the dashboard is going to fly off the firewall. I will look at the mid pipe hanger because I know mine got tweaked a bit.
Did the OP of this tread ever solve his issue?
Rick Simons
I realize this is an old post, but it still has relevance (for me, at least). I've mentioned this in a previous post: a buzzing vibration comes in between 2000-2100 rpm. It's pretty loud most of the time, but other times it's quieter. Turning left while it's occurring makes it more pronounced. I get it in every gear, and intermittently in neutral.
I've been dealing with this issue ever since I installed Prothane mounts, Ebay LT's and X-pipe, and high-flow cats.
I have approx. .120-.187" clearance between the steering shaft and nearest header tube on the DS, and roughly the same amount between the frame and nearest tube on the PS.
The list of things I've found and fixed that could have been causing this contains:
1. Loose tail light cover. Replaced the plastic push screws with plastic rivets.
2. Muffler hanger hanger hook on DS touching isolator bracket. Bent hook to gain clearance.
3. DS muffler (Flowmasters installed by PO at a muffler shop) rattled when I hit it with my hand. Replace with JBA axle-back system.
4. x-pipe. Fitted stock H-pipe, no change so I went back to the X-pipe.
5. Loose lower bumper cover. Replaced fasteners.
6. Spare tire cover. Removed temporarily.
7. Loose jack. installed foam under it, then secured it.
8. Vertical (shift lever shaft) spherical bearing in my Hurst shifter could float up and down approx. .010-.020" within the bearing housing. Glued it in with Loctite.
9. Aftermarket cat touching one of the heat shields. Removed factory heat shields and installed thermal barrier sheeting. I have a minimum of 3/4" clearance around the cats now.
10. Installed 4" long flex couplings between X-pipe and tailpipes.
11. Pulled the center console (it sounded like the noise was coming from under the console towards the front) and found that the connectors for the Dual head unit were sitting on the bare (un-carpeted) metal of the forward part of the trans tunnel. Insulated the connectors with foam padding.
12. A/C hard lines along PS inner fender. Temporarily isolated them with foam.
13. When I disengaged the lower shifter boot from the floor tunnel and drove it to hear what I could from under the car, the vibration was barely noticeable. When I re-installed the boot, it came back. I noticed that the rear shifter mount compressed part of the lower boot, so I shimmed the mount away from the floor by about 8mm, so that it wouldn't "capture" the boot. No joy, buzz was still there.
The next step is to get it in the air and see if I can induce the vibration/buzzing while I'm underneath. This will require a helper with a steady foot to manipulate the throttle. I've held off on this step as I suspected that with the car on jack stands the dynamics that are contributing to this buzz/vibration might be changed or removed when the car's weight is borne by the frame instead of the tires. It's worth a try I guess.
What's really odd is that everything I've done seemed to fix it temporarily, but it always comes back.
I'm just about ready to pull the headers off and put some clearance in the tubes that fit the closest, then re-install the stock motor mounts. I don't really want to do this because it shifts so much better with the stiffer mounts and the Hurst shifter.
I'm tempted to do the TSB mentioned above, but I'm not sure how well the rear part of the exhaust system would be supported by the flex couplings. I guess I could take them out, since they didn't produce the desired results anyway.
*Light Bulb!* I bet with a little effort I could pop the rubber inserts out of the mid-mounts and see if this changes anything. That way they wouldn't be permanently damaged.
As always I'm open to suggestions.
Rick Simons
So, last night I removed the isolators and the mounts per the TSB listed previously in this post. I could easily see how the steel isolator brackets could have been vibrating in the X-member.
Unfortunately I still have the buzzing, only it seems a little worse now. It's gets louder when I turn the car sharply to the left just like before. I can't seem to get it to buzz with the car standing still. Looking at putting a camera underneath the car. :angry1:
Pentalab
A Go pro camera + strong light....has found many suspension issues in the past.
dustyn83
Had the same issue. The culprit was the loose bolt on the exhaust hanger.
