Joser281
:worth:
Only question is: if you do it with water, how do you align the stripe and keep it from sliding and becoming slightly crooked? Does it get enough "wet stick" to not move too much while you squeegee the water out??
i did my stripe without water, but it was me and a very experienced vinyl guy doing it
It's very easy the wet method, start with the hood or roof stripes since they are the easiest, no tricky curves. For the bumpers spend a little bit more time and use a heat gun or hair dryer to help with the corners. USE A LOT OF SOAP AND WATER is my biggest suggestion. and try not to use a credit card, I have so many customers complaining that their vinyl is scratched from installation, this is because your using a credit card!! Get a felt squeegee, their only a few bucks. If you can't afford that, then get a piece of left over vinyl and rap the credit card with it and then use it as a squeegee
I put my side stripes on flawless, soapy water and squeegie.
Not that hard.
^i can help too
Anyone that's down!! I'll solicit more
help when Columbus day gets closer!
no never use a needle that Is wrong. Felt squeegee and soapy water is all.
