bigray327
SOLD
Well here's something you won't see every day here... a Vortech V2 SQ trim head unit, just the head unit. It was used for 40,555 miles by yours truly. Satin finish.
This is a fixer-upper...
$280 shipped with a 3.33" pulley, not installed on the unit.
FAQ:
- It absolutely needs new seals, and I'd highly recommend it gets new bearings at the same time. Vortech charges $400ish for this job, other places do it for cheaper.
- The impeller is in perfect shape, but while it's visiting Vortech, you can have the Si trim impeller put it, which is another $400 or so.
- Two of the mounting holes are partially stripped. There are threads remaining, so you'll need two slightly longer bolts than what comes with the stock kit. Vortech might be able to fix this. This sale includes just the head unit, no bolts.
- The volute has an oval-shaped abrasion that was caused by a radiator hose rubbing against it. Cosmetic only, no performance issues with this. Vortech might be able to fix this.
- The mounting orientation is set up for an air-air intercooler. If you'll be using it with an air-water cooler or no cooler, you'll need to adjust the mounting orientation, which involves loosing a few bolts, sliding an adapter, and re-tightening the bolts.
- Someone that wants a kit on the cheap. You'd have to buy literally everything else, which conveniently can be had from superchargersonline.com for [FONT=verdana, arial, helvetica]$2,678.00, part number [/FONT][FONT=verdana, arial, helvetica]V3FU218-030[/FONT][FONT=verdana, arial, helvetica]. You'd also need a tune, sold separately.
[/FONT] - [FONT=verdana, arial, helvetica]Someone that wants to upgrade or repair their daily driver's head unit, and doesn't want a lot of down time, rental car costs, etc. That's exactly what I did several months ago, which is why I have this for sale now.[/FONT]
FAQ:
- Why does this thing have oil all over it? Like I said, it needs new seals.
- Can I install this right onto my Vortech V2 setup? Sure, but it won't last you long without new seals. And stock up on Simple Green, you'll need it.
- Will this work with my V1 setup? Yeah, but I think you'll need a different mounting bracket, which can also be had from superchargersonline.com or from Vortech.
- Does this come with everything else? Nope.
- Does this come with ANYTHING else? Nope.
- Seriously, nothing? Seriously, nothing.
