MMR Oil Filter Relocation Kit for the 4.6
1950StangJump$
I originally bought this because I didn't have clearance with my suspension setup to get my oil filter on and off easily. That's not a concern now, so selling this relocation kit. I used it for 1500 miles.
It will work on the 4.6 and the 5.4. It is in good, used condition. I had it mounted under the pax side headlight, and it includes about 5 feet (x2) of braided, 10AN line that allowed me to run from the left side of the block.
I will also include the high quality 90 degree AN fittings for at the block that "swoop" for higher flow, and 45 degree fittings for at the top of the relocation bracket itself. The kit allows for a sensor at both the block location and the relocation bracket; I have screwed in plugs in case you don't need them, which can obviously be removed for sensors. I will also include two brand new Wix oil filters of the correct size.
I'll include the used o-rings for the bottom of the bracket at the block, but I'd recommend you pick up new ones. They are cheap, you'll need two size 120s and one 134, preferably Viton. I'll include a sample from my tube of Hylomar AF, so they you can coat your o-rings for better sealing.
Price is $130 shipped to CONUS. Pay Pal only.
akylekoz
I'll take it.
Trying to figure out how to send you a PM.
