Water Pump help
Logan541
2014 v6 convertible. I accidently bought the the three bolt pully and pump instead of the 4 bolt pulley and pump. My question is since it came with the 3 bolt pulley can I use it any way ? Are the pumps interchangeable? Are the pumps the same expect for the pulley?
06 T-RED S/C GT
Carnegie, PA
If the water pump is specifically for a 2014 v6? then it would obviously have the correct 4 bolt pulley. If it doesn't? more than likely it's probably not the right pump for your specific model year v6, to begin with anyhow.
All new Ford water pumps for the Cyclone are 3 bolt. My kit included the correct pulley too. That is the only difference AFAIK. Aftermarket brand pumps still come in 4 bolt so you can reuse your old pulley if that is important to you.
