Weight shifting noise or brakes
richiet9
miami
It feels as when im coming to a complete stop im getting noises either
from the rear unloading or somewhere in the braking system....
killr3v
Hector G.
Katy, TX
What kind of noise? Cold or warm car? Stock or aftermarket pads? Stock suspension?
richiet9
miami
tokico d specs shocks bmr suspension meaning all the control arms relo brackets and sway bars
eibach prokit springs
bmr panhard bar
car has 35k miles on it
makes the noise more when its cold than hot
dysan
Dis-Member
Williamstown, N.J.
Mine does that but I believe it's my spherical upper control arm that makes that sound.
I would check your bushings...especially the rubber one that is on top of the rear differential. Mine was shot when I had it replaced with a poly one.
Thebighouse111
NJ
Did checking the bushing solve your problem?
I've had the same issue since I got the car 3 years ago. I'm all stock but it only happens when coming to a complete stop as well.
