What pads do you use?
007GTCS
So yesterday we finally had a nice day. I buffed and polished my car, and applied a sealant. I have been using chemical guys 5.5 hex logic pads with a porter cable 7424 xp. Well I use orange for buffing, white for polishing, black for sealants and waxes. I had two orange pads fall apart on me. One just flying off the velco back. Has anyone had these problems? If so do you have a pad recommendation?
Thanks
Also glory shots of the car :)
28ONE
The City
Never had that problem. Try out Lake Country Hydrotech's or Flat Pads...
HitandRunDriver
Amateur Goon
Orange, California
I use the low profile hydrotech pads. How old are your pads and how do you care for them? If the foam wasn't in great shape or the adhesive on the backing failed I could see how they might fall apart.
007GTCS
They were two brand new pads, maybe 2 months old. I prepped the pads, via chemical guys process. And I have never had this happens before either. I may have just gotten a bad batch. But I was just curious what else was out there, or if there is a better way to prep?
28ONE
The City
I'd call CG up and tell them your new pads fell apart. When you prep the pads, are you covering the entire surface with product? Only thing I can think of is defective pad or you're generating a lot of heat, lack of product on the pads surface, causing the adhesive to lose its strength thus falling apart. Hopefully you just had some bad pads...
Grabber
Coyote Snob Member
Wheeling, IL
What speed setting are you using on the PC, how much pressure are you applying?
Are you keeping the pads lubricated and adding some detail spray in between coats? How much product are you using?
I've never had a pad fall apart on me in over 8 years of working on cars. At most, a yellow pad started to "fade" after about 15 hours of actual usage between various cars.
007GTCS
Light pressure, speed of 5. Usually I pack the pad with product. And use about 5 dime size amounts in between sections. I don't lube in between. And I have never had it happen before either. To be honest I think I may have just gotten a couple of bad pads. My white pad did fine. Same With black. But at the same time I want to learn, and tricks I can to maybe help in the future.
Grabber
Coyote Snob Member
Wheeling, IL
Use a spray or two of detail spray with the product. Helps spread the polish and adds a bit of lubrication to the pad.
Speed setting 5 is optimal for a PC. Sounds to be a bad couple of pads. The Velcro backing should not come up even under heavy pressure and high speeds.
Bossmustang16
3v to 4v
Yadkinville NC
I use the hydrotech pads as well. perfect results and simple and easy to use. 3 pads and you can play around with your products to get the exact result you want. however, the 3" hydrotech's were absolute garbage!! I guess there not perfectly round or something but they won't even spin properly for me. It's like there cocked over. have to use the LC Flat pads for the mini ones but hydrotech all the way for 5.5's
