What wide band are you using?
Embalmer
Amateur Expert
Amboy, Illinois
Innovate LC-1 with their OT-2 wireless setup streaming the data to my iPad.
dagamore
Poor Driver mod
K-town Germany
Innovate LC-1 with their OT-2 wireless setup streaming the data to my iphone,
upgrading to twin LC-1 very very soon, have the bung welded in just need to put in the sensor and wire it up.
Riptide
Will work for Mustang.
Montucky
You guys are logging your AFR to an iphone? That sounds pretty slick. Is that an Innovate thing or something SCT came up with?
Embalmer
Amateur Expert
Amboy, Illinois
Innovate has what they call the OT-2. It plugs into your data port, and broadcasts the data wirelessly to an iDevice of your choosing. I have my LC-1 connected to the OT-2 via serial cable, so it will send that data as well.
The OT-2 also has a bunch of other features, you should check it out.
http://www.ot-2.com/
Riptide
Montucky
So if you are using this to log your AFR then how are you integrating it with the data tables from the SCT tuner when you log the other paramters (like rpm, etc.)?
Embalmer
Amateur Expert
Amboy, Illinois
The Innovate hardware and software work together. The LC-1 sends the air/fuel data to the OT-2, and it integrates that data into the live wireless stream. My iPad receives all the data (up to 16 parameters at once) and I can log as much data as memory I have. This data can be exported as a .CSV file, the same format that SCT uses. Basically, this replaces the SCT's datalogging equipment and all the wires that go with it.
Here is an example of the parameters the OT-2 can log:
