Where to buy a complete 8.8 custom built?
redstangs9308gt
Is there such a place where you can order a 8.8 to fit our cars custom built to your spec? I thought about going with a full 9 inch swap but I think that might require another driveshaft mod. I would like to get a new 8.8 built to have 3.90 gears with some upgraded posi unit type (air locker etc etc)... I seen ford racing is selling two 8.8 kits. One has a 3.55 and the other a 3.73. I would like to get this took care of over the net without drama and shipped to my door step :)
BoostedGT480
Slow 3v
Montgomery, AL
I know someone selling one thats already built... Go to ModularPerformance.com and go to the garage sale link
actually here it is
2005 8.8 Mustang GT Rear End
Housing welded and braced
Powdered coated after welding
Stock axles
True Track Locker with 4.10 gears
Girdle
Comes with TRZ suspension
Adjustable upper andlower control arms
Anti-sway bar
Adjustable cross brace
http://modularperformance.com/200588mustanggtrearend.aspx
Flapjack
Lunatic engine swapper
Colorado Springs, Colorado
I believe brenspeed has a deal going on. Check them out.
JPC gave me an excellent quote on a fully built 8.8 with a TrueTrac in it. I've yet to order, as I haven't put the built block in the car yet. It's definitely next on my list, though.
I wasn't able to find anything near the same level of "complete", not to mention the price was great. Not going to quote it, as it is now over a year old.
Sent from my Android using Tapatalk
Hysteria
0 .· ` ' / ·. 30 psi
Tampa, Fl
How much power are you planning on making?
The rear comes with 31 spline axles and if you replace the differential with a TuTrac or a Detroit Locker, and change the studs, the rear will be very strong.
I have a Trutrac in mine and it holds up well with 1.47 60' times.
redstangs9308gt
When I had the 127550 cams I was making a little over 530rwhp @ 93octane on a mustang dyno.
Hysteria
Tampa, Fl
What did you do with the 127550 cams? Were you the one that sold a set recently? I'd like to get a set.
