MrClean
Marc; but I go by MrClean
So I'm going to get one....to try to reduce unbdersteer (I'm a corner carver), and body roll.....Roush? Saleen? Any and all suggestions welcome. Experiences in trouble-free installation are a plus....
And did you purchase from them directly? or through a vendor? ThanksBMR makes a nice beefy rear bar and the bushings are top-notch. I've had no problems.
Picked up the set from LMPerformance. Price was right. http://www.lmperformance.com/7784/73.htmlAnd did you purchase from them directly? or through a vendor? Thanks
I'd get the whole shooting match.Thanks. I'm wondering if it is worth the extra $181 to get the front one too (the f/r kit), as I've read the front stock bar is pretty good....or shall I just get the rear?
Just make sure you hand lube the bushings with synthetic grease. Don't use a grease gun on the fittings or you'll risk splitting them.Thanks for your input guys...I got the BMR
Thanks for the heads up...you're talking about the bushings that slip over the ends and get bolted to the axle close to the wheels, right?Just make sure you hand lube the bushings with synthetic grease. Don't use a grease gun on the fittings or you'll risk splitting them.
Thanks! I got the rear only since I heard the improvement over the stock front was minimal, but I'm sure it will be an improvement. And I can't wait to get the Tokico's...I've already started working on the wife...I installed the BMR front and rear on my car just before running an On-Track event at Nashville Motor Speedway and man did they perform awesome!! Car was a true corner cutter... even going through the s's, the instructor was very impressed. Of course having the Tokicos adjusted proper was a big help too. BMR... great choice!!
Redbaron66: what springs are you running? 634 rwhp??? WOW forged internals + whipple @20 psi?I installed the BMR front and rear on my car just before running an On-Track event at Nashville Motor Speedway and man did they perform awesome!! Car was a true corner cutter... even going through the s's, the instructor was very impressed. Of course having the Tokicos adjusted proper was a big help too. BMR... great choice!!
I'm running Steeda springs all around. And Whipple @ 20 lbs... not for me. I'm running a Vortech at 15 lbs wit a 75 shot of giggle juice to cool the intake charge, with forged rods and pistons, stock crank and block.
Cool, let me ride in it once you do it so I can determine how much stiffer it is over stock.ive been lookin at the H&R springs to make this swamp lookin buggy into somthin respectable
