BigRis
Just would like to hear from guys running the Roush 560R . Likes,Dislikes , performance etc...any info. Thanks
Just buy it.
Are you going to build the motor too?
I have the 2010 TVS tuner kit with the GT500 dual pumps.. Looks to be the same thing Brenspeed is selling with a BAP rather than the GT500 pump.
It's a really easy install, You can install it yourself in 12-18hours with a minimum amount of tools. I installed mine in 12hrs. That included a lot of WTF breaks.
Performance, With the OE manifold and stock catted H-pipe.With a 3.5" pulley it made 9psi and 460rwhp/430rwtq.
Installed a 3.25" pulley and 11.5psi, and made 485rwhp/460rwtq .
Added Comp Cams 127300's, made 505rwhp//480rwtq.
It's a very streetable blower, I've put 30,000 miles on mine since I installed it.
The only thing wrong with it is, with 4.10's and the 3.38 1st gear traction will be an issue.
BigRis spend the $500 to get the GT500 fuel pumps. Don't want to go cheap when it comes to fuel. Yes I know tons of people are running fine with the BAP but I'd rather have more than enough than just adding voltage to run the pumps harder.
Get the fuel system upgrade from Jeremy at S&H.
Good move! Jeremy knows his stuff!
