Watch your compression ratio with that rotating assembly and the procharger.... That setup you listed is 9:7:1..... How much boost do you plan on adding? You might want to drop into down to a 9:1 or 9:3 combo.
Can you use this on a stock block and safley up the boost OR should i build up a new block ... REALLY REALLY new to the internals world when it comes to boost.
whyask, the car looks wicked!!!! Dude where did you get that stripe kit?? That is the Roush scoop right?? I need to do this stripe setup =).. PM me the info if you can.
So is it me or is it amazing how a good shop can not only getthe car and 4 plus grand in parts to there shop with out it getting stolen..... Cause we all know sd's dumbass can get shit stolen like that hahaha
@Grn: Again, im not educated enough in the boost world to really tell you,lol. I want to be able to see above 500hp easy with out the fear of killing the engine. So im guessing around 12 since 10 and below ..from what ive seen and heard is somewhat safe. I have the Fore Triple Pump and 60lb injectors being added with this build.
@Retro: Stripe kit i had done at a vinyal sign shop. They bad it for me there on the spot.. Needs to go back as the rear right side is slanted inwards. NOT really noticable but im anal about my car.. and the scoop is Roush Correct
