Windows and Radio not working?!
V-6Power
I was changing the radio out in my car and I heard a faint poo, and now my radio and windows no longer work. I've check the fuses under the hood, and in the panel by the passengers feet under the kick panel.
I can't figure it out, but would love to have my windows and radio working again.
Thanks in advance.
JUSTA3V
Moar Throttle!
Queen Creek AZ
Have you located the fuses that operate those systems as per you owners manual? Are they ok? I know you said you checked fuses. But you didn't elaborate
V-6Power
I checked all the fuses in the car. The only thing I haven't checked is relays, but I don't have a voltmeter to do so.
KatoS197
Addison, TX
Have you checked your pants? :roflsquared:
I'm sorry, I had to.
Found this:
I found a 5 amp fuse in the passenger compartment fuse box that had blown. The windows work now, but now on the driver’s side window will go down automatically, but will not go up automatically. The passenger side works fine. I suspect that someone tried to break into the car, because the driver’s door feels like something is blocking it slightly. It doesn't have a solid feel like the passenger side. But at least I can go through the drive through window.
And a response:
Try the window reset procedure. Roll the windows down and hold the button for an additional 2 seconds. Then roll them up and again hold the button for 2 more seconds.
V-6Power
I see my typo. Lol
But I read That as well and even tried the procedure. I'm just super stumped.
AbdullaGT500
Little Rock, AR
You checked every single fuse or just the fuses for windows/radio? Check fuse number 6 in the interior fuse panel on the passenger side kick panel.
V-6Power
Just wanted to update and say it was a fuze that was unlisted but located in the SJB.
