WTB 2011-13 stock coyote 5.0
MSgt46270
Ford Racing NMRA Coyote Stock Sealed Engine
Item # MA50346
$6349.99
Shipped - U.S. shipping only, No APO, Ships in 5-7 business days
Product Features
  • 5.0L 32-valve DOHC "Coyote" sealed crate engine
  • Designed for NMRA Coyote stock class
  • 11.0:1 compression ratio
  • 412 horsepower @ 6500 rpm
  • 390 ft-lb of torque @ 4250 rpm
  • 80mm "drive by wire" throttle-body
  • Lightweight Aluminum Block
NMRA Coyote Stock Class. Specially designed for the NMRA Coyote stock class this brand new all-aluminum Coyote sealed crate engine is a modern 5.0L 32-valve DOHC V-8 that features Twin Independent Variable Camshaft Timing (Ti-VCT) to deliver over 412 horsepower @ 6500 rpm and 390 ft-lb of torque @ 4250 rpm (with premium fuel).
Built Ford Tough. This Ford Racing crate engine is built from a lightweight aluminum cylinder block that features cross-bolted main bearing caps and thick main bearing bulkheads for bottom-end strength. Includes manual transmission engine harness and flywheel.
High Revving Efficient Power. An 80 mm single bore "drive by wire" throttle body in combination with a tuned composite intake manifold provides efficient air delivery and weight savings. The four-valve-per-cylinder aluminum heads with roller-finger followers reduce friction while piston-cooling jets, optimized oil drain-back and windage control improving high-rpm performance.
Application. This sealed 5.0L 32V DOHC Coyote Engine is designed for the NMRA Coyote stock class and is a direct fit replacement for 2011 Mustangs with engine code BG-397-AA. Can also be used in a resto-mod or a custom car build.Technical Note. Does not include vehicle harness, PCM, alternator or engine cover kit.
NOTE: Ships Continental 48 States ONLY. No Canada, APO/FPO, Hawaii, Alaska, Puerto Rico, Guam or Us Virgin Islands.
If shipping to a business, please include the business name. Also, after your order is placed, be prepared to let us know if you will need a Lift-Gate service. You will be contacted via email before your order ships.
MSgt46270
Same one, higher price but with free shipping.
Ford Racing Coyote 5.0 4V 412HP Crate Engine
Item # MA50189
$6299.99 SHIPPED ships US only, no APO, Ships in 5-7 business days
Product Features
  • 5.0L 32-valve DOHC "Coyote" crate engine
STEVE_POE
coyote powered fr500s
Cincinnati
Item # MA50189
Product Features
yes that one is free shipping as well. anything over 3500 is free shipping from ford racing.
Thanks
Mike at diversified is free shipping as well.
http://www.buyfordracing.com/products/5.0L-4V-412-HP-MUSTANG-CRATE-ENGINE.html
2005mach1
michigan
I have everything but a block and crank
all good condition used - less the 9000 miles
STEVE_POE
Cincinnati
thanks , I just went with a new motor from ford racing. I now have a complete motor I'm going to sell with a bad # 8 ....lol
Mike K
WANNA BE FAST
Richfield, MN
I was going to tell you to get a hold of CPR he has one that he is going to be getting rid of.
STEVE_POE
Cincinnati
how bad is the block hurt on #8? - maybe I can take it off your hands
I have not pulled the head as of yet. Got the motor on a engine stand , rolled the motor over and pulled the pan. Ran # 8 all the way up and noticed some very minor scratching on the clyinder wall. Guessing we broke a ring.
Car was still running fine just started to have white smoke out the tailpipes and we pulled the plugs and #8 was oil soaked. Was just going to try and hone the cylinder and re ring the piston but just didn't have the time.
Ken b is interested in the complete motor possibly if I can come up with a price but honestly I have no clue what it's even worth.
KenB
between $5-$10. Don't worry about checking that price, I'm an expert. :highfive:
