wtb a front turn signal harness
leviathon
Erwin, nc
welll...I unfortunately need a turn signal harness for my 06. Anyone got one laying around?
07gts197
Naples, Fl
You need the whole harness from the sjb all the way to the lens? It might be cheaper/easier to rewire it yourself than to try and find the entire harness.
leviathon
Erwin, nc
Sadly yes, the plug had 2 burnt spots and tried to rip one wire completely out.
07gts197
Naples, Fl
Like I said it’ll probably be easier and cheaper to rewire it yourself.
leviathon
Erwin, nc
Maybe....guess i need to figure out how to get those pins out and try and clean off the burn...if i even can
leviathon
Erwin, nc
yes thats the end i was originally talking about. long story short my turn signal was ripped out and took wiring with it. i fixed the obvious failures right at the light and actually a little further up the wiring harness but still didnt have a turn signal...as i dug deeper i ended up at the fuse block plug and discovered i had 2 shorted and burned contacts in there with 1 half ripped wire.
07gts197
Naples, Fl
My bad I didnt read your original thread about the issue. If the contacts are still ok you can reuse the pins and splice in new wire or you can find another harness with similar pins, depin the connector and put them in the old connector.
leviathon
Erwin, nc
Yeah finding the harness is the problem haha
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Are you still looking for that harness? It has the cooling fan as part of it, too, hence the 'burnt pins'. I have the whole harness (except maybe for the horn connector or some other connector and maybe except for the foglight connectors, but the side lights are there), and one of those pins is dark/burnt-looking too, but all the others are ok, so a good one could be made out of yours and mine. It's from a '07 gt, if it makes a difference.
leviathon
Erwin, nc
I did find one from a salvage yard here, except the front was smashed...so i clipped the plug off and see what i could maybe get from that..also Dean from Kohr has one that I may purchase from him...if he does have it lol
