Wtb.. Blow thru setup
black N boosted
Boosted
Perkasie Pa
Looking to convert my draw thru setup on my novi2200 to blow thru, anyone selling there setup or know where u can purchase pieces.. Thanks
BruceH
BBB Big Bore Boss 322
Jeremy should be able to help with that. He sells pipes with the maf fitting installed and also sells the extended maf that's needed for blow through.
Changing the air intake is fairly straight forward. Just get a silicone elbow and aluminum pipe that will fit with a filter installed. www.siliconeintakes.com is a good source for parts. Jeremy might have a setup for the intake too, not sure.
black N boosted
Boosted
Perkasie Pa
Hoping he chimes in, if not I will shoot him a message! Thanks again
Northwest Subs Chicago
Jeremy made an intercooler for me with the maf mount on the outlet, it really helps having the maf in this area for drivability tuning, cleaner signal. I use to have it on the up pipe right before the TB and the variation in MAF counts was much larger.
black N boosted
Boosted
Perkasie Pa
Where are u running the bov then? Don't u run it off that side as well? Any pics? Thanks
Yes the BOV is on the drivers side, here is a couple of pics of the setup with Jeremy's S&H intercooler and bracket support during fitment. The maf mounts on the output of cooler. The only thing I've changed on the setup pictured is I've moved the meth injection to the intake manifold from the up pipe and of course put on T-bolts and constant tension clamps.
You could probably have Jeremy modify an existing intercooler but having them make you one comes with new radiator/cooler support and with or without swaybar bracket mounts. This really free's up a whole lot of room getting rid of the stock support.
