AutoXRacer
I got the plates from Steve at TASCA...a lot cheaper than what you guys paid!!
Is that Steve who use to work at tousley? I know he left but don't know where he ended up.
He ended up right here on the forum. Steve@Tasca is his user name and he's a forum sponsor.
+1
I've just had the same thing happen to me and ended up with a broken right side chain guide using the iron tensioner. Needless to say, I'm using the plastic tensioner when I reassemble.
Reassembled with plastic tensioners, as well as installing the V10 VCT deletes. (Note: the thread that's going on now with the NAPA freeze plugs to fill the holes are 2005-2006 valve covers... To big to fill my 2008's...)
I don't have mine apart yet but.... loud as shit till warm. Once warm completely normal. Put about 100 miles on it testing the trans. My bet is the steel tensioner is malfunctioning. Ordering some Monday and going full retard while I have it apart
Sent from my Nexus 7 using Tapatalk
What did you use to seal your valve cover?
Any words for those planning to do this?
Also... michael.. did yours ever get quiet or did it totally fail? Mine will ratchet up after about 10 minutes of idle.
I am wondering if this contributed to a data log I had way back that showed variations bank to bank?
So 8 degrees of retard ideally?
Had same problem and I used them as caps instead of inserts.
Caps?? So you just placed them on top of the hole?
How is it being held in place?
Got pictures?
I was able to find new plugs in 36.3mm and 36.5mm.
I will see how these work. I am hoping the 36.3mm work with a slight press fit. I am planning to hopefully press it in with some RTV to have it seal perfectly.
