298....tr6060.....67mm@20 psi.....in progress!
probercr93
Banned
Fort Wayne, IN
Wow, that looks great! Reading through the build thread I was seriously hoping you were able to get the forward facing headers to work. I've contemplated doing that to my build, but seeing all the problems you had I think I'll scrap that.
Reading through these build threads makes me wish that I had done a build thread as well. I guess I could start in the middle... lol
one eyed willy
Pizzle fo shizzle
Lakeland FL
its possible to do the headers, but you would have to modify the A/C lines.....thats the only issue i had....and wasnt wanting to do that
one eyed willy
Pizzle fo shizzle
Lakeland FL
ITS ALIVE!!!!
got my throttle body issue resolved!
took the car for a short 10 mile drive, all temps look great,pressures look great, not a single drop of fluid leaking from anywhere and A/F is around 11.3-11.5.....
meth kit is working good, around 3psi the kit kicks in and my temps drop a good 10 degrees almost instantly!
got it home and checked all the fluids.....changed the oil !
now i just gotta do some work on the tune!
transmission is shifting good! i really like this KR shifter and im 100% satisfied with it...not even sure why people waste money on anything else...
JeremyH
3V Fuel Guru
Virginia Beach
Awesome! I really like the stock gt500 shifter, have no issues with it. The throw is short and precise. Guess I dont know what Im missing or vice versa for you lol
What gph nozzle are you using on the meth setup?
one eyed willy
Pizzle fo shizzle
Lakeland FL
video video :) also what was wrong with the TB?
i guess the TB sat too long, 4-5 months.....then i over clocked the spring to make things right, which gave me a different code so i knew i was working on the correct issue.....so once i got the spring clocked correctly...it was working good!
spring only gets clocked 1/2 turn for those using a BBK TB , for who ever reads this later!! there are 2 different holes for the spring to sit in on the BBK gear.....if you have to clock the spring 1 full turn to get the plastic gear to line up then you are using the wrong hole!! only 1/2 way is all it takes!
one eyed willy
Pizzle fo shizzle
Lakeland FL
car is down again...turbo is blowing too much oil for my likings.....anyone has any rebuild info im all ears....
i tore it apart and the rear oil seal is blown for sure, i need to find a rebuild kit ASAP!
GT500KR
Quad Cities, IA
oil drain restriction too... ran in to that problem with my STS rear mount on my 70 Camaro needed a better oil scavageing pump... also are you running an oil restrictor like GB10 said? some fitting have them built in some dont... hope this helps
one eyed willy
Pizzle fo shizzle
Lakeland FL
i bought it used with 1000 miles on it, problem was there from day one when i got it (i got fuked pretty much!)
I HAVE A #3 feed and 3/4 drain with zero kinks....i do not think i contributed to the issue.....dude i bought it from fuked me....but ill get it fixed, no biggie!
GB10
8s coming soon?
Burleson, TX
Yea, 3/4" drain and -3 feed is what I use with no problems whatsoever. I run a Bullseye turbo, but with a T4 turbine a 3/4" drain should be sufficient.
bmaxwell
BÆST
ATX
^ I remember you talking about these turbos, they look to be bad ass to me. How on earth can you get them 200-300 cheaper than straight from comp lol.
