tr6060 and cruise control
stang910
Jacksonville, NC
I just installed my 6060 and tried using cruise control in 5th and it didn't work. Works in all other gears, but 5th. Anybody have this problem?
klaw
Calgary, Alberta
I tried cruise control once after installing my Whipple HO and it was annoying as hell. I've never tried it since upping the boost and swapping in the 6060.
mustang1200
Badass
When my car at the 4lbs pulley and the stock Saleen tune the cruise was super annoying. Surging badly and making me nearly sick. After I went to the 11lbs pulley and the JDM tune the cruise works fantastic. I'm not what the difference is other than the mods, but I was happy it started working great.
stang910
Jacksonville, NC
Everything works great. No problems with cruise at all in any gear other then 5th. When trying to turn it on it just won't turn on at all. Upshift into 6th and it works. Downshift into 4th and it works. 5th gear nothing at all. Really wouldn't bother me, but I have the .50 6th gear so I have to use 5th for slower cruising.
ZmanM3
The Evil One
Jackson, NJ
Cruise works in 5th gear on my t56. At least I am pretty sure I tried it in 5th and it worked, I would have noticed if it had not.
HG6283
Granny Shifter
Shrewsbury, PA
Anyone have an update on this topic? I just installed a 6060 and have the same problem. No cruise control in 5th gear. 4th and 6th are fine.
JeremyH
3V Fuel Guru
Virginia Beach
I will try it tommorow and report back. I have a 2010 6060 with the lower od gears btw.
Litebulb
Doesn't work with my 6060 either
Sent from my SAMSUNG-SGH-I997 using Tapatalk
JeremyH
3V Fuel Guru
Virginia Beach
Works for me. Tried it today in 4th 5th and 6th and worked fine.
2010 6060, reverse lockout not hooked up.
redstangs9308gt
Mine works in all gears also but hold up wait. It only works as long as the car is pulling. As soon as it goes to coasting down a hill it kills the cruise controll and I have to reset it. lol.
JeremyH
3V Fuel Guru
Virginia Beach
Also my tune was adjusted after the swap to mimic the gt500 tq multiplication tables etc.
TurboX
Formally Buzz Lightyear
San Anto,Tejas
Very interesting, Im gonna ask my tuner about this when I get my car retuned. I too have a TR6060 swap and cruise doesn't work in 5th gear
94tbird
4R70W FTMFW
mine never worked in 5th when i had it, jsut 4th and 6th. why would you cruise in 5th anyway. you got 6th, so use it
JeremyH
3V Fuel Guru
Virginia Beach
I use 5th all the time in 55mph zones.
I only use 6th above 65mph. at 60mph 6th gear is around 900 to 1000 rpm and drones bad.
At 80 I sit around 1400 rpms in 6th
How does that affect driveability, since the 4.6 toque curve is different than the 5.4?
Drives perfect!
From what i understand my tuner mimic'd the gt500 tables then made a few tweaks.
