Connector under console?
TX
When I was installing my mgw shifter , I took the console apart and found a connector that was just hanging back in the back. My car has sync, ambiant light and all so I assume its for factory dash screen/ nav does anybody know what this is for, thanks
it's for the flux capacitor
seriously tho, your description is very lacking in detail, did you get a photo? near impossible for anyone to know with what you posted IMO
gtmiller1001
Houston
i know what your taking about and also have a premium with no nav
i have no idea what it's for, but i do know one of the wires is a keyed 12V :)
i'm assuming it's something for the nav as that's the only option i don't have, or maybe something that would be used for an auto trans car
JeremyH
3V Fuel Guru
Virginia Beach
The 05-09 had that too. Cant remember if it was manuals that had it or for heated seats or something.
302
Atlanta GA
My base car has it also. I really don't think it has anything to deal with the dash components. Lightblade might be on to something with the heated seats. My friend has heated seats in his, so i guess i could take up the console and take a peak next time i see him. /shrug If not, its probably something for the autoshifter because the letters illuminate for that.
Interesting it is switched 12VDC though. I could think of some uses for that. :)
gtmiller1001
Houston
I have heated seats and the connector isn't hooked to anything
Maybe it's the part that makes the car shift normal and the engine stop ticking :)
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Can someone post up pictures of this connector and label which wire is switched 12V? Also, is it switched to ignition ON or just ACC?
gtmiller1001
Houston
I think it is heated seats, I have them and don't recall having any extra connector last time I had the console cover off.
I am here: http://maps.google.com/maps?ll=29.728170,-95.463837
It's not for heated seats.
I will tonight if I have time. Easy to determine if you have a multi meter though... just start w/ignition off and get a good ground (you can use part of the stock shifter assy metal if I remember correctly).
Start touching wires with the positive lead and the meter set to 20V DC.
If you come to one with no voltage and the ignition off, turn the key to accessory and watch the meter, should go to 12V if it's a keyed signal. The one I found was a 12V with just ACC, car did not have to be running.
I have, however, had a multitude of weird electrical shit lately while installing NOS, so maybe it was a fluke. I ended up wiring my arming switch to the power for the cig lighter outlet in the center console as I don't use it for anything ever. It's 12V hot all the time, but I have to arm the system anyways so it doesn't really matter to me.
94tbird
4R70W FTMFW
if its behind the center console, its prolly heated seats, but if its under the shifter console, and your a stick, its the electrical harness for an automatic shifter.
ZXMustang
5.0 4V Owner
I thought it was the connector for the convertible top? It would be for the switch.
302
Atlanta GA
Oh come on electrical engineer, you can figure that one out. :beer:
Yea right, sold separately from ford i'm sure. :(
stang1971
Kansas City Mo
it is NOT for heated seats. the hvac unit controls the heated seats as the relays for both seats are under the drivers seat. i found this out when i wired in my nitrous... the passenger heated seat turn on wire turned on my bottle heater and the driver side armed the nitrous system. should have seen the looks on people faces when they searched my car for the nitrous switches and couldnt find them..lol
FalconGTHO
The Reporter
Scorpion Gulch
Sneaky. And clever.
hawkeye18
omgwtfbbq
All of you. Yeesh.
^^THIS. I went through this a few months ago when I installed my Tri-Ax. Nothing to be worried about.
