gmantheman
Not 3-4 but .3 to .4 .I am going to say your bama tune was way off. N/A I just don't see that much of a variance between a good email tune and a dyno tune.Were not exactly talking about 3-4 hp difference here...
Maybe Chris can explain.
I have their(BAMA) tune and as far as drivability, it's a tune that is hard to beat and I've had other email tunes too and they SUCKED!!!!!!!!!!!!!!
I've datalogged my tune and sent it directly to Chris Rose and he reviewed it and assured me it was spot on. I'll wait for Chris' input.
You cant know if a tune is spot on without verifying it with datalogs and AF readings.
so I was told that 1* or less of knock is acceptable. while I trust the source of this what are other opinions?
I've seen that dip on so many email tuned 5.0s. That dip is basically the tuner commanding to much timing to quickly. So the car will knock and retard the timing.
If you datalog it, I guarantee you'll see knock in that range.
because engines in general all function similarly. Drastic dips like that are almost always attributed to knock. When you see itnin a 5.0 though its almost always after 4800 rpm.Why would 5.0's have the same dip as this guys 4.6?
Dyno issue possibly then. I dont see how 3 cars would have the same dip on the same dyno without it being a dyno issue.
have them log for KR, my money is on that. I've never seen a steep drop like that unless the AF fell flat on its face or it was KR.
