351inside
Anybody know what the top of 4th is with 373s & a 28" tire? Or better yet will I have to shift to 5th in the 1/4 mile with a 100 shot?
Yes, you will have to go to 5th.
I'm in the same boat. I just got quoted 1100 bucks to swap out the 3.73's to a 3.55.
I keep going back and forth on what to do. A smaller OD tire would let you use more of 5th but it's still not right. All the math says 3.55
Any one find a solution. Seems some have just stuck with the 28 and got a tune to up the rpm. They have turned good times but I'm a little scared to do a tune right now.
What did you guys end up doing? I know this tread is a little old so maybe you guys have tried some thing and got some results?
I assume that quote was from the dealership? If not, run from the guy charging that amount!
