So I've reached out to the S197 community before about my issue with the FRPP intake manifold with no real responses, and from what I've searched no one else seems to have this issue with the manifold, so I thought I would bring it to tech before I make a deicision on keeping it on the car or going back to a stock manifold.
Current hardware for reference:
FRPP Intake Manifold
Comp Cams 127020 (Thumpr Stage 2 NSR) w/Comp Phaser Limiters
Pypes LT Headers & O/R X
JLT CAI
At about 1/2 throttle around 3,000rpm the engine stumbles and pops. I can baby the throttle past 3,000rpm and it will rev through clean. I can free rev the car at any throttle position and it won't stumble or pop. At WOT starting below 3,000rpm the engine still stumbles a bit and gets a little poppy going through that 3k/rpm range. So it only does it when the engine is under load in that rpm.
My tuner has tried everything he can think of, and even consulted other tuners on the matter and they've agreed with his methods and had no further input other than it's a hardware issue, such as the cams, and not a tune issue. The car isn't pulling timing when it stumbles, but we even tried running it on race gas just to be sure, and no effect.
BBR says it's the comp cams. But TBH the Thumpr's aren't a terrible grind, what most people don't care for is the LSA and weak lift. The duration is actually a nice profile at 234/[email protected]". I like the sound and wide power curve of the cam, but no it doesn't make the most peak power. If it is the cam causing this issue, then my question would be why? What is the thought behind it? Is it the issue because it's not an aggressive enough cam for the manifold? I had the cams in long before the FRPP intake and LT headers, and the car ran absolutely flawless and never had an issue at 3k/rpm, or any rpm for that matter. I find it hard to believe the cams are the issue, when I didn't have the issue until the FRPP went on. I'm not gonna dump $1,000 on a blind fix. Saying comp has shitty grinds isn't a good enough reason. Tell me the LSA is bad for an aftermarket intake, now we can go somewhere with it.
I'm scheduled at the dyno shop next wednesday, so I really hope I can get serious feedback on this. If not, I'll go with my gut and swap the manifolds.
JLT CAI
