stock fuel pump install help
circusboy
is the pump supposed to sit down all the way in the tank. I have to push it down about a 1/4 inch to make the lip seat in. I'm having problem with the re-install. What dirrection is the level float supposed to go. I don't see where the arrow on top of the pump is supposed to point either. HELP lol
05mustang_TT_charged
Because Race Car!!
LSU Country
The arrow should point towards the front of the car. The level sensor should be on the passenger side of the pump when installed.
bcb06gt
Mandeville, LA
See if this helps. Something I used when I replaced my stock pump (06) for a later (08) stock pump
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
The float level has to go over the barrier/lip that separates the driver side from the passenger side of the fuel tank.
Pretty sure the arrows show you where the line up tabs are.
circusboy
Thanks guys. I got it to seat, but don't have enough hands now lol. The daughter can't swing the hammer worth a crap lol. I'm gonna stop for now and start again tomorrow.
8306gt
Conroe, Tx
No extra hands needed, push it down, turn it to lock it in place, and then install lock ring. It's all very simple, should take more than a couple of minutes. I just removed my stock pump and installed the GT 500 last week in about 15 minutes including removing and reinstalling the seat.
JeremyH
3V Fuel Guru
Virginia Beach
You got lucky!
I have removed installed fuel hats probably a dozen times and i think ive got the lock down tabs to hold maybe two-three times and it was easy peasy. The rest were it would lock down but as soon as you tried to twist the ring it would pop back out, very finicky,makes it almost impossible without a second set of hands when it does that.
05stroker
Never enough power guy!
Bullard Tx.
You got lucky!
I have removed installed fuel hats probably a dozen times and i think ive got the lock down tabs to hold maybe two-three times and it was easy peasy. The rest were it would lock down but as soon as you tried to twist the orring it would pop back out, very finicky,makes it almost impossible without a second set of hands when it does that.
Damn,I guess there is somthing else I have been lucky on me car then.
15 or 20 min swap for me.
GuySolo
I’ve been having the same issue, where the pump pops back out. What were the steps that you’ve taken to keep it down while putting on the locking ring?
You got lucky!
After doing the pump a few times I have found a couple little things that help me out. For some reason the access hole doesn't line up with the pump so I like to unstrap the tank and let it hang down a bit. This makes it easier to maneuver the pump into the tank. Second I got (not this particular one) fuel ring tool. Even though it says not to I put it on my impact gun so it is easy to manipulate. Hold the pump down with one hand and use the tool to maneuver and secure the ring, squeeze the trigger once and done.
https://www.amazon.com/OEMTOOLS-243...ocphy=9030746&hvtargid=pla-504073488927&psc=1
Laga
Chicago
Before you start, use a needle nose pliers to SLIGHTLY bend down the tabs on the locking ring. Makes getting them started much easier. I also put a light coat of silicone grease on the bottom of the locking ring to help things slide easier.
