TPS Slotted, Dimpled, or Cross Drilled Brake Rotors-from $259.99 FREE SHIPPING!
tpsmak
TPS Motorsports Brake Rotors
-Available in Slotted, Slotted/ Dimpled, & Slotted/ Cross Drilled
-Each rotor is made by Centric (Makers of Stoptech & Powerslot)
-Very High Quality Castings... these are NOT eBay Rotors.
-Black, Gold, or Silver Zinc Coated
2005-2010 Mustang GT-$259.99
2005-2010 Mustang V6-$259.99
2007-2012 Mustang GT500-$299.99
2011-2012 Mustang GT w/ Brembo-$299.99
2011-2012 Mustang GT-$299.99
2011-2012 Mustang V6-$259.99
PRICE INCLUDES 4 ROTORS!
FREE SHIPPING INCLUDED!
Click here to place an order!
http://www.tpsmotorsports.com/catalogsearch/result/?q=TPS+Mustang+rotor&x=0&y=0
TPS Motorsports from day one has always been about bringing the best value and service to our customers as possible. We are now proud to roll out our line of slotted and slotted/dimpled rotors. These rotors are made by Centric, which is the parent company of Stoptech and are a very high quality rotor. Our rotors are FAR superior than lower priced “eBay” rotors. We have tested our rotors on customers street and open track vehicles.
Which Rotor is right for me?
One question which is always asked of me is which type of brake rotor is better.. slotted or cross drilled? Before answering this question we need to ask.. what type of driving do you do? If it is mostly a street car, then cross drilled rotors will be fine. Cross Drilled rotors main benefit is they look great and do offer some heat dissipation and a wiping effect of the pads when wet. The main disadvantages for cross-drilled rotors is they have a history of playing connect the dots.. cracking. If you are very hard on your brakes or take your car to the track I would suggest slotted rotors. Slotted Rotors on the other hand offer great heat dissipation. Better braking than cross-drilled because of increase braking surface over a cross drilled unit. Generally a solid rotor is 100% material touching the pad, slotted is about 92% and drilled is 85%. More braking surface means better braking power. SLOTTED ROTORS IS WHAT WE RECOMMEND FOR MOST CARS ESPECIALLY FOR OPEN TRACKING AND AUTO-X
Why do you have Slotted/ Dimpled Rotors?
The main reason we offer Slotted/dimpled rotors is because they offer the desired look of cross drilled rotors for many customers without having the issues of cracking. This is a “compromise” option to have for those who like the cross drilled look without having to go with cross drilled rotors.
Why don’t you recommend Cross Drilled Rotors?
Because they tend to crack over time when subject to heavy use. Most companies including Baer, Stoptech, AP Racing DO NOT recommend CROSS DRILLED ROTORS for track use. We offer it as an option BUT ONLY recommend it to customers who’s cars do not see much track duty. They also offer less braking surface than slotted rotors which means less braking power.
Why are your rotors black?
The black coating is a special zinc coating to prevent the rotors from rusting. The black where the brake pad meets the rotor will be gone after driving about 50 miles while the rest of the rotor remains protected with zinc.
Here is the picture of the rotor AFTER about 10 miles of braking. The Black zinc coating will wear out on the surface where the pads meet.
tpsmak
We now have rotors available for 2011-2012 Mustang GTs!
2011-2012 Mustang GT500-$299.99
-Includes 2 front & 2 rear rotors
-Includes free shipping
tpsmak
Who needs some rotors? These great rotors are made by Centric who owns Stoptech. These great durable rotors :thumb2:
cm581978
NJ
I've had these rotors installed for a week, along with the HPS Pads. Absolutely love them!
tpsmak
Just ordered a set. Hopefully they will be in by spring break when im off to install them.
Rotors ship in about a week from ordering... so you should have them in plenty of time for Spring Break :)
KryptonKnight
Fallston, MD
I have been looking to get new rotors and have seen many designs. I know there are heat, weight, and gases issues
2 Questions. Why are the holes drilled in an arc pattern? It seems like they would function even if drilled in a straight line.
Why do the slots stop before the edge of the rotor? It seems like they would function better if there was a outlet to the edge or the rotor..
tpsmak
If they are slotted all the way they may crack at the edges. The are drilll and slotted at a arc pattern because when the car is braking the rotor moves while the car is slowing
Hiltsy845
Any discount on these for forum members, or do we pay the same as Joe Blow on your website? Looking for a black zinc coated set for my '08 GT.
tpsmak
Not on the rotor sets because we priced them at a smoking price already ;)
tpsmak
Who else wants a set of the best rotors for the money?
