TPS Slotted, Dimpled, or Cross Drilled Brake Rotors-from $259.99 FREE SHIPPING!
SleeptGT904
Jacksonville Florida
Please PM me on a price for 05 GT slotted black zinc rotors.
I do have GT500 take off's in the front with 14' rotors. Also since you sell them in a set of 4 will the stock GT brakes fit them?
tpsmak
Just placed my order!
Thanks!
If you have GT500 brakes in the front you will need to order the GT500 Brembo Brake rotors from us. ALL Mustangs have the same rear brakes regardless of what model they are... V6, GT500, GT CS... etc?
MexGT
Mexico
Difference between slotted/dimpled & slotted x-drilled ? from the pictures they look the same, sry for my stupid question ! lol
If I only want the front rotors for Brembo Calipers, I'm looking for the $199 ones right? Because the description says:
Product Description
TPS Performance Brake Rotors for 2005-2010 Mustang GT provide better stopping than the stock rotors and the performance look of slotted/ cross drilled and zinc plated rotors is an outstanding visual upgrade. These rotors are designed to eliminate out-gassing while minimizing stress cracks. These rotors are made by Centric the owner and maker of $3000 Stoptech brake. We then have them custom slotted/ cross drilled to our specs.
-Stops Better Than Stock Rotors
-Slotted/ cross drilled For Performance Look
-Bolt-On Installation
-Fits 2005-2010 Ford Mustang GT, 2011-2013 Mustang V6
-Includes 2 rear rotors
so its kinda confusing there.
Thanks
bullitt ben
Ordered!!
Just ordered a set of cross-drilled/slotted rotors and HAWK HPS F&R pads....can't wait to slam these on...
Thanks Mike,
Ben
MexGT
Mexico
Just ordered Front GT500/brembo slotted & drilled black zinc rotors.
:beer:
Professor
Nixa, Missouri
If slotted rotors have less surface than plain rotors, what is the advantage? Is it just visual, or is there any empirical evidence that they reduce stopping distance. I like the look, I'm just not sure if there are real advantages worth the extra dough.
tpsmak
The advantages of our rotors are
#1-They are slotted so they have a wiping effect on the pads and also helps with out gassing the pads.
#2-They are Zinc coated to prevent rusting on the non-fire path areas.
Our rotors are really not much more expensive than the stock units... if you break it down it's about $60 per rotor after shipipng.
stephen1371
Afghanistan
just placed my order went ahead and got your stainless brake line kit to, this is by far the best deal i have seen on both items
