Haha I saw the review you posted...why are you already moving on??
I used Zymol Vintage, just wanted to try it out.
How much?
I'm fixing to place an order with auto geek just to get me started.
Already have cutting/polishing pads and a PC.
What are some personal recommendations for white? Obviously it's difficult to get any depth out of it. I've been on other detailing forums but wanted to see what some of you recommend.
call early. They can fix it.I messed up my order from autoality sent them an email hoping to have it sorted it out.
its awesome they have a retail side. 7 days a week hours.Called today and the owner is the only one that can fix it. The guy I talked to took my info and told me call to tomorrow to check up
Sent from my DROIDX using Tapatalk
Lava can be grabby to remove, but so far all higher end waxes with decent durability. I mean pinnacle souveran buffs easy but usually only lasts about 2 weeks.
Seer....quick question for you...
I currently use CG VRP and Bare Bones in my regimen....You mentioned a few days ago that those two products seem inferior to blue guard (Which I will be ordering after I exhaust my supply of both). What are your thoughts on CG G6? I always looked at it as a higher end VRP
order got fixed and I changed it bit also.
Microfiber Applicator Pad, 4-pk.
Grit Guard Insert - Red
Daytona Speed Master Wheel Brush
Fine Grade Clay Bar (Dark Blue), 200 Gram
Finish Kare 425 Extra Slick Final Body Shine, 31 oz.
Chemical Guys Grime Reaper All Purpose Cleaner, 128 oz.
Take a look at Ultima Tire & Trim Guard... The stuff is amazing... For trim it can't be beat IMO. I use it on my tires as well and I can't tell you how much I love it.
How long does this typically last? From the write ups it says months, but I'm used to things being exaggerated.
No it really does..
