Had great luck with my spark plug removal!
calispecial08
APRIL FOOLS!!!!!
Despite having an 08 I got stuck with the old style plugs.
Seems I couldn't get any luck with this. Broke all 8 of them suckers. Followed the TSB on every one of them, seemed to do no good. Used PB blaster on them and I let them soak over night..didn't seem to help AT ALL.
Guess my car had too many miles on it. Luckily I was able to go pick up the Lisle spark plug tool from Oreilly's, it was by far more expensive than i could have found it on the internet but I didn't want to wait.
Already had NGK plugs sitting here at the house ready to go in, guess I should have researched a bit more, gonna send them back to rockauto and order some HT0s probably.
Does anyone make a one piece 1 step colder plug for the older style heads? I saw that Champion and Brisk both make 1 piece plugs? but do they offer them in the 1 step colder versions?
bunkered13
brenham tx
how many miles does the motor have? im curious because i have an 08 with 42,000 on it and my plugs came out fine.
calispecial08
same here man......
only one of them ended up not breaking the tip, going to get some 1/4" hose tomorrow and i'm gonna rig it up to the vacuum cleaner and try to suck everything out of the cylinder..I tried to suck as much as I could with the hose I had today but the hose was too big to fit down through the spark plug hole.
calispecial08
yeah thats what I was going to do once I find someone with one lol
calispecial08
alright thanks I will definitely be checking there and autozone tomorrow!
the end on a borescope is small enough to fit in the spark plug hole right?
3VPOWA
East Texas
I used FRPP plugs in my car while running nitrous. They're one piece and 1-step colder. I have the older style heads on my '08, too.
Arizona
Jesus i got all mine out with no pb blaster or anything at 61k miles.. replaced with he ht0's and their nice, i recommend them, good luck with it all and make sure there's nothing in the cylinders
calispecial08
yeah it blows, hopefully with the borescope i should be able to make sure I get everything out
ctt326
Brenspeed Hater
Fort Wayne, IN
Damn, all 8? that sucks! I replaced the ones on my 07 when it had about 45k on it and they all came out without breaking. Just broke them loose a tad let some PB sit and slowly wrenched. They screamed the whole way out but none broke. I replaced them with HT1's then, but now have HT0's and have been in and out about 3 or 4 times with no problems. Make sure to use a little antisieze on the install as well.
calispecial08
yeah I'm gonna use a bit of antisieze on them and after this they will be changed at lease every 10K..
how many of you guys w/ F/I changed your plugs again after getting tuned and running about a tank of gas though? one of my buddies told me that after I get all tuned and everything it would be a good idea to run a tank of fuel through the car and then swap plugs again? but if this is not necessary I don't want to have to do this again right off..
Arizona
two of mine came out sqeeking a bit.. and that bothered me.. but in general it all was pretty easy i just used a socket wrench and broke them loose making sure i was right on top of them then used a socket extension to take them out by hand and took it easy on them
calispecial08
I turned MAYBE an 1/8 let them soak with PB, came back turned them easy and worked them back and forth like it said to do...didn't work for me as you can see...haha
