Hey guys i am looking to update my gear for the end of this season. Just wonder what everyone is using, pros/cons of what your using. Does any one run a cool suit- what brand do you run. thanks guys
It was summer like warm that weekend in NJ.Pyrotect SA2005 helmet: A little on the heavy side, but it fits my miniature mellon to a tee with an XS shell, and small cheek pads.
Sparco balaclava: Mandated, works fine.
DefNder head/neck restraint: Love it. Very comfortable, side tethers are the icing on the cake.
OMP One FIA 8856-2000 suit: Very comfortable, and actually affordable!
FAST Cool Suit: Just the ticket for enduros! I got the one with the timer, and you just swap out frozen gallon containers of water with the driver changes.
Sparco nomex socks: Mandated. 'Nuff said.
Sparco Tide gloves: Absolutely awesome. Incredible wheel feedback, tremendous grip.
Sabelt racing shoes: They fit. Great pedal feel, however also great pebble feel, if you wander around the paddock in them.
exactly what i was looking for , what size tank do you use for the cool suit and how do you have it mounted? i will look into the rest of the equipment you are using.
13 quart, and in the CMC car ('94 Mustang) we've got it where the passenger seat would go. In my S197, I'm going to mount it in the trunk somewhere, probably on the passenger-side, on top of the frame stub, depending on how the corner-weighting winds up. If you buy one, make sure you get the one with the timer! Instead of just running full-bore, it turns on and off (variable) to extend the cooling time, and to keep you cooler towards the end of your stint. The hot ticket is to freeze a half-dozen or so plastic milk jugs full of water, and just swap those out on driver changes, rather than trying to scoop out water to make room for more ice.
If you have pictures i would love to see the install. do you have link to the setup you are running?
it gets hot as balls down in texas!
