Opinions: SS lines, Rotors and Pads
2005redgt
Lake Jackson, TX
Guys,
I am looking to replace my brake lines with SS lines. At the same time I am thinking about getting slotted and/or drilled rotors and pads. I would like to hear some feedback about what you installed and your opinion.
Thanks in advance.
-Bryan
94tbird
4R70W FTMFW
R1 Concepts or Rotorpros for the rotors, Hawk HPS Pads and Earls SS lines.
I have the R1 Concepts Drilled slotted with no issues or complaints hps pads and earls lines
DirtyDeedsInc
Groesbeck, Texas
I put in the Earl's lines and can tell the difference. I'd recommend them. Other than pushing the brake pedal, that's all I've done to my brakes.
GRAYPNY
Rich
NorCal - Chico
Same here and they work great. Whatever rotors you buy I recommend painting the inside of the holes or the slots high temp black. They will show surface rust after awhile.
LAK3RS
Original Member
DFW, TX
- Rotorpros Drilled/Slotted Rotors (rotorpros.com)
- Hawk HPS Brake Pads (rotorpros.com)
- Steeda/Goodridge Brake Lines
- Motul RBF 600 Brake Fluid (brenspeed.com)
scramblr
New Braunfels, Texas
Big Top Gt
Coral Springs, Florida ~ 33076
I've got a brand new in the package set of stainless front brake lines sitting in my garage.
They came with my Saleen 14" brakes, but I've already got stainless lines on the car.
If you're interested, I'm sure I can help you save a few bucks. :)
Otherwise, you'll notice a difference with the pad and line change, more than the rotors. (if at all.)
Honestly, the pads are where 90% of the difference will be found.
pcdrj
Bucks County, PA
If you track the car, drilled rotors will crack. Last week I had one crack through the whole rotor.
SoundGuyDave
This Space For Rent
+1... Unless the brake package is engineered with drilled rotors (Corvette with the ceramic rotors) the heat will expand the rotor past the point where it will hold together, and it will crack, starting at the holes, which act as stress risers. Hell, I crack OE, undrilled rotors, never mind cross-drilled...
2005redgt
Lake Jackson, TX
Then why bother. The stock brakes are good. Even those who are road racers, on other forums, have said the only required upgrades are ducts and pads.
The main reason was the SS lines, to get some bite back once the brake fluid warms. I do hit high top speeds, both on the highway and the 1320 - So the pads and SS lines seemed likle a good idea. The rotors are going on to add some show. I have spent alot of time/money on both show and go.
-Bryan
