Tie Rod Ends
ren274u
North Carolina
So my tie rod bushing are shot ripped on both sides. I will be replacing my ball joints (with extended lengths) all the front control arm bushings at the same time. I'm wondering if i should get a bump steer kit or just go with the FR500C extended tie rod ends M-3130-R2.
All the car has now suspension wise are Progress lowering springs, koni shocks and jm camber plates. I plan on getting some strano bars and endlinks in the future.
Thanks
Fuerte
I was going to get a bump steer kit but on one around my area could install it. What is the difference between m-3130-r2 and the moog ones?
Sleeper_08
Thanks
How much do the Progress lowering springs drop the front and rear?
The normal "rule of thumb" seems to be you are OK if it only around a 1" drop at the front.
