Slammed on 19's, post your pics.
whtcanbrwnd04u
San Marcos,TX
That looks great man. :clap:
Morris
Pop the nub off, I had to take mine off when I put on my Avant Gardes. Nothing wrong with doing it either, its just a cheap plastic piece that the center cap will act in the absence of.
Hmm it does say "do not adjust, do not remove, permanently lubed" right on it.
I can't get the thing off with out mangling the shit out of it. It's sort of glued on so I wouldn't be able to put it back.
What's it look like under that cap? Seems like they went to some trouble to seal it that well. I think that maybe it needs to be sealed to keep the greese in when it heats up?
I started to take mine off but now I'm thinking I need to do some research on it.
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
Here is one more, black rims are not easy to show. Not sure how feel about the look.
The rims are Linea Corsa LC818's
Have you considered maybe some white paint to accent the rims? I found a set of rims similar to these locally for a great price, but I'm not 100% sold on the all black; I'd want something to break it up.
Morris
Well, plastidip does come in white so you could play around a bit with it I guess. Strange how the wheels look better in person up close, but from afar or in pics not so much.
Morris
Got a shimmy in the wheel, guess I need a re-balance even though it was road force balanced.
Overtorqued
Got a shimmy in the wheel, guess I need a re-balance even though it was rode force balanced.
If you just pulled your factory wheels off and put the new ones on, check this: there is a single washer on one wheel stud for each wheel that helps hold the disc in place with no wheel mounted up. If those are still on there, remove them.
The factory wheels have a countersink on the back side at each lug hole, and this washer fits in there. So, the factory wheels will mount to the hubs flat. Most aftermarket wheels don't have the countersink on the back side, so the washer will cause the wheel to be just slightly crooked, but it's enough to cause a shake in the steering wheel.
Morris
Good catch, I will check that out and see if my wheels are counter sunk and if not remove the washer. Either way this little washer could be a big thing for some one dealing with a balancing issue.
I think I found the offending wheel though. I rotated the R side and the shimmy went away from the wheel and moved to the seat. So now I know I need to take the RR wheel back in to the shop.
neema
Fresno, CA
Too many white mustangs.
sigh... still looks good though. are your wheels deep concave in the back? your car looks good. are you running on 20s? i need to get wheel specs for the next set ON because 285/315 20s are going on.. and the car is going to be dropped lower. i'm stupid.
Phuck Phace
Dallas
Mine? I wish they were deep concave, for some reason they didn't offer that on a 20x11.
jayman33
My 19x11 f14's concave is pretty deep. Still wondering if I can fit a 335/ 30 on there. Hmmm
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
neema
Fresno, CA
weird. you'd think forgestar would have no problem selling a deep concave wheel for the 20x11 if they do it for the 20x10.5. still looks good
nitrobob
Missouri
Needing some help and figured this may be a good place to ask.. I am wanting to lower my car either with coilovers or springs/shock route. Not wanting to slam it but would like to get it to sit lower to get rid of the 4x4 look below. I do not track the car but do drag race on occasion maybe twice a year. Mainly a cruiser/car show ride. Ride quality is important to me. Car is on 19's RTR. Can you help me out...:helpme:
nitrobob
Missouri
How much drop can I achieve with those?Which BMR springs don't want to drop so low I rub on my tires.
