flaming70vw
- Joined
- Jun 13, 2007
- Posts
- 82
- Reaction score
- 0
Would a K&N panel filter an offroad h-pipe and straight thru mufflers cause a lean condition without a tune?
Yes it will.Would a K&N panel filter an offroad h-pipe and straight thru mufflers cause a lean condition without a tune?
See my post on catless H pipes. Although it is not real common, my car had severe knock when I went catless on an otherwise bone stock engine (not even a CAI). I datalogged in LiveLink and off my wideband, and the H pipe was absolutely the problem. When I put my stocker back in, the problem went away.
As I said, most people have not had this problem. But a reputable tuner told me that he is seeing it more and more, especially on 08's and 09's for some reason.
The moral of the story is that there is a chance the mods you mentioned will cause a lean condition. It did on my car. Get it tuned after the mods and you will be ok.
Thank you for all your replies. It runs good now the CEL is on but that is because the rear 02s are not urned off. I think i will try it.
you can go down to napa and buy two sets of spark plug non-foulers and drill one and stack the other(do this on both sides)... it will keep the CEL from showing up when you clear it...
or you can buy the CEL eliminators
more on the fouler please... how exactly does this work.. curious..
