BMR Panhard keeps coming loose?
BV600
TEXAS
So Ive put locktite 242 on this damn thing 3 diff times, and the lock nuts come loose and the rear end shifts to either side.
SO what locktite should I use or what am I doing wrong?
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
Put some ass behind it and wait a little while before taking it out on a test drive. I had a problem like this with my LCA jam nuts. Put the locktite on, waited a couple of hours for it to set, then took it out. No more clunks or potential shifting.
Most will tell you that it doesn't take Locktite a couple of hours to set up, which may be true, but this worked for me. I also used RED locktite. It may not be necessary, but it helps me sleep better at night.
put some ass behind tightening the lock nuts lol...
Mine on the other hand are stuck and I cant loosen it to adjust!!
PB Blaster and/or heat (propane torch) will loosen those nuts right on up.
Scott_0
OxFORD, Pa
Use a big ass wrench on the jam nuts, should stop it from loosening. I'm not using lock tight and mine doesn't loosen
BV600
TEXAS
I had to use a huge breaker bar to get the lock nuts loose the last time it came loose, So im thinking I have to tighten it that way
fdjizm
Drag Queen
Mine are big dog crab arm tight, no locktite, they never move.
