Best Camber plates? Which ones?
6605stang
CSM No. 07SGT5687
Denver, CO
Just like it says... going the way of adjustable caster/camber plates and would like some input on what your experience is with them.
Thanks in advance, JR
06silverbullet
orange county, ca
j&m makes excelent quality products at an extremely reasonable price,
maximum motorsports are excelent probabaly the best you can buy but cost is very high.
AutoXRacer
Florida
I second the J&M plates...got those on my car and love them!!!
Although they are not at the same level of adjustability of the MM ones.
All depends what you're looking for...street/strip (J&M) or all out race (MM/Steeda).
6605stang
CSM No. 07SGT5687
Denver, CO
You ever had trouble adjusting them? And how much camber can you actually get out of them? I have a buddy that has the J&M's and says he can only get -2 out of them and they are always sticking on him. Do you have the Street or Race version?
Schwettmann06
killeen TX
I'm running the MM ones and I love them. I can't remember how much adjustability they have exactly but it's a lot.
Fuerte
I have the MM ones I had like 2.6 degrees of adjustment on them. Super easy to install no bearing in them so no need to worry about that it does use the old rubber mount from the stock mounts and a metal plate.
Sent from my SCH-I535 using Tapatalk 2
6605stang
CSM No. 07SGT5687
Denver, CO
2.6 would work for me. But one thing, I was just reading their website and it says this...
"Improves dynamic alignment stability by eliminating stock rubber-bushed upper strut mount."
But your saying the rubber mount stays? Are we talking about the same ones?
http://www.maximummotorsports.com/s...=product_info&cPath=514_2_77&products_id=1151
AutoXRacer
Florida
I've never adjusted them...the alignment guy has and his comment was he loved them!! Easy to work with. I think max adjustment is 2 degrees out of the street setting and a little more out of the race setting.
Depending how you install them, you can set them for street or race...the race has more degrees of adjustment I believe.
http://www.hotpart.com/shop/index.php?l=product_detail&p=64
And no stock parts are reused...this replaces completely the stock one.
6605stang
CSM No. 07SGT5687
Denver, CO
AutoXRacer
Florida
Ya, and J&M says 1.8... so I must be missing something because I've heard people say they've gotten 2.5-3.0 out of both. Not sure where they disconnect is. I want to be able to get at least 2.0 MINIMUM out of the set I get though.
I'm thinking the disconnect is people don't know what they are talking about... lol
How do you know you absolutely need 2.0...?
You're only option seems to be is to buy one and try it out.
I think that are all in the base ball park of adjust-ability due to the limiting design of the strut towers. I believe thats your limiting factor. Without modifying the strut towers, I don't think you'll be much more.
All I know is that the J&M plates have two ways to install, street and race, and they gave me enough adjust-ability to have correct camber on my car which the stock strut plates did not.
AutoXRacer
Florida
It is an additional 1.6 of adjustment.
Additional from what? Stock...? I doubt it. Its 1.6 degrees of total adjustment.
  • 1.6-degree continuous range of camber adjustment, adjustable without affecting caster.
  • 0.7-degree continuous range of caster adjustment.
DRock
yes stock........say you go in for an alignment and your camber after putting lowering springs on is -1.3...........with the MM ones you would get another 1.6 degrees out of them, so you could either be at +0.3 or -2.9 degrees. It isnt that hard
And usually you can pull more so than that to go negative.
Fuerte
WOT
South Florida
I picked up set MM CC plates from the classified and they where a bit of a pain to install into the mount but the again I was doing the install by myself.(had no rubber band)
Once they where in I could easily say they are easiest CC plates that I've ever adjusted.
Cammed 05
Always happy
VB, Fl
My buddy bought the J&m. Nice piece for the money. That said I went ahead and spent the money on the MM. Glad I did and very nice piece also.
