HELP!!! --- Long post on random car stalling.
RRRoamer
No one else (including two dealers) have any freaking idea what is going on, so it's time to ask help from all of you! Warning, this first post is going to be long as I have done a LOT to this damn car trying to diagnose the problem!
Summary: The car will stall. Usually, it will stall when you hit a bump or crack in the road. "Sharper" jolts TEND to cause it to stall more often than softer jolts. But, it won't do it when the car is cold, nor if it was cold and you just start it up and drive. You have to drive it for a while (10, 15 minutes) and THEN let it sit for 1/2 and hour or more. When you get back in, it will run perfectly fine for anywhere from a minute (hot days) to 10 minutes (colder fall days) before it first stalls.
Normally, the car will start right back up like nothing happened by either pushing the clutch in and hitting the starter (no need to turn the key off first), OR you can just push the clutch in, wait for the engine speed to drop below about 300 rpm (when the oil pressure light and check engine lights come one), then let the clutch out and it will start right up.
It will start stalling more and more frequent until it almost wont run (I'm been on the side of the road trying to get the engine restarted more times than I want to admit), then the stalling will get better and better until it goes away completely. During the hot days of summer, the time between first and last stall was about 10 minutes. Now that the high is only in the fifties, it can take up to 25 minutes or so before it clears out and runs right.
Other indicators: The vehicle security icon will USUALLY (but not always) come on right after a stall event. It will USUALLY stay on for a couple of seconds then go out. The car will turn over but NOT start so long as the vehicle security icon is lit. Occasionally, it doesn't come on at all (maybe it came on and went off so fast it didn't light up the icon?) and occasionally it will stay on for five seconds or so.
ODBII codes: My XCAL2 has NEVER found a single code related to this problem. At the dealer, there MATCO scanner also did NOT find any codes. BUT, the IDS system DID find two codes, P0689 and P0670. One code is because PCM thinks the ignition is on and PATS does not and the other one is just the reverse of that. More on ODBII codes later...
What has been done to date:
  1. Crank, Cam and MAF sensor replacement (cheap sensors and easy to replace)
  2. MAF connector replacement (explained below).
  3. Replaced both PCM#1 and PCM#2 replays.
  4. Replace the TPS sensor.
  5. VPWR at pins 35 and 36 on C175B datalogged .
  6. PATS module Pin Point Testing followed with no issues found.
  7. Pin Point Tests for P0689 and P0690 followed where possible (explained below).
  8. Datalogged alternator voltage on both DC AND AC scales.
  9. After all trouble shooting was completed, every Pin Point Tests last item was "if problem persists, replace PCM", so it was.
  10. Datalogged VREF voltage at MAF.
  11. Lots and LOTS of cussing.
Let's see if I can make sense out of this list. The problem started out at about 38,000 miles with a VERY occasional stall. Maybe once every couple of months, and it pretty much went away completely last winter. This spring, it came back and has been getting worse and worse.
So, my first attempt at "fixing" this problem was fairly well shotgun: what sensors did I think COULD possibly cause the problem, then replace them. Most of those sensors are pretty cheap and I don't mind having them around in case it turns out the original sensors where still good. I started with the crank sensor (the most obvious cause), then went to cam sensor (but I REALLY didn't think they would cause it as they are generally only used to sync the engine during startup).
During my trouble shooting, it SEEMED like the problem would go away for a few days to a week when I messed around with the MAF or CAI (JLT2). I tried returning the car to stock (that sucks by the way) and the problem DID go away for about a week. I decided I was ON TO THE PROBLEM(!!!), so I went ahead and replaced the MAF ($130, so I wasn't quite as fast to replace this sensor!). No dice. I actually replaced this one in the parking lot of the parts house so I wouldn't have to bring the core back. The car stalled on me not 150 feet from their drive way!
That led me to buy and replace the MAF sensor connector. And that REALLY hurt as I had been trying to keep all my wiring as intact as possible, but you have to cut and splice to replace the connector.
At this point, I decided I just had to get some professional help (of the automotive kind!!!) and the next time it started stalling on my, I headed straight for the nearest Ford dealer. I was able to talk their senior tech (their "electronics" guy) into plugging in the IDS system and going for a test drive with me (actually, it was the $100 they where going to charge me for test drive that convinced them, but still...).
This drive was a bust. One, half way through the ride, his laptop battery died and he didn't have the car charger with him. Two, the car never stalled once during the test drive, so he didn't get to see what was happening. I had explained in detail what was happening and what I had done so far and he did have another suggestion: swap the PCM relays with other relays in the BEC. It's free troubleshooting. It also didn't do shit to fix the problem. On the bright side, because his laptop died, I didn't get charged for the test drive either...
His other suggestion (based on seeing similar problems on a few older Mustangs) was to replace the TPS sensor. Again, no change at all.
My next visit was a few weeks later and to a different dealer. One of their senior techs had me bring the car in on a Saturday morning and he spent about three hours "off the clock" going over it with me. This one started out VERY promissing as he found two ODBII codes as soon as he hooked up the IDS: P0689 and P0670. Unfortunately, there are no Pin Point Tests for these codes for 2005 Mustangs. They ARE in the 2006/2007 service manuals, but there is a change in wiring between 2005 and 2006, so 80% of the actual PPTs where not able to be performed on my car.
He did go through the schematics and identify what the PPTs where TRYING to do on the 2006 and then came up with some tests that we could do on my car. This mainly resolved around verifying that we had constant power at pins 35 and 36 (VPWR from two different sources) during the stall events by data logging the voltages here. Needless to say, like everything else, these tests proved there was NO issues with power coming into the PCM during the stall.
His other suggestion as a possible cause was to data log the AC voltage at the battery. He had seen past cases where the alternator was dumping AC onto the battery (and then the PCM) because the rectifier was going back and the diodes where intermittently shorting out. Once more, data logging showed there wasn't an issue. I had a max of 110mV (0.110V) of AC AT THE WORSE CASE and normally had around 50mV of AC at the battery. This didn't change during the stalls.
My next attempt at getting help on this was a call to a Master Technician who is a service manager at a Ford dealership my mom works for. After discussing the issue in depth with him, he wanted to do some more testing on the PATS module, even though we both agreed that PATS can not kill the car when it is running (it is only a starter interrupter). The PPT on the PATS module all passed and I found myself once more staring at the "if all other tests fail, replace the PCM" line.
So, it was back to the dealer and they did replace the PCM. Under warranty actually as the PCM is part of the emission system... Of course, the very next day after the PCM was replaced, it stalled about 10 minutes after I left the restaurant where I had lunch...
Since then, the tech has talked to two different Ford engineers about the problem, but neither one has gotten back to him with a possible solution.
I talked to another tech at the same dealer and he suggested I test VREF (the reference voltage used by pretty much all the switches and many of the sensors) to see if it is being shorted out during the stall events. This was datalogged on the MAF and there was no real change during the stall event. Plus, every single place where VREF leaves the PCM, it is behind a pull up resistor. So even if a specific sensor gets shorted, it won't affect any of the other sensors or switches.
Other Thoughts: The PCM is not losing power during the stall event. I say this because the dash does not go through it's power up cycle with the idiot lights being turned on, etc. I even tested it by starting the car and then quickly turning the key to accessory and then back to run. The car did die, but the PCM was obviously reset as well. It's almost like the PCM is fooled into thinking the engine should be shut down.
Questions On Active Security: My car does have the factory installed active security system (aka: alarm system). I specifically get the factory system because I did NOT want some aftermarket alarm installer screwing around with my electrical system and causing issues down the road...
Does anyone know if the active alarm system CAN kill the engine while it is running versus the PATS which can only stop it from starting? Does anyone have any ideas on how to trouble shoot possible alarm issues?
Hell, does anyone have any ideas at all?????? Needless to say, after this ordeal, I would be MOST GRATEFUL for any assistance!!!
RRRoamer
I know this has me stumped, but I figured someone here would have an idea... :)
ArtQ
Alpha, NJ
Shot in the dark, not sure if the chip in the key would do this, but maybe try using the spare key.
Other thought is a sensitive fuel cut-off
W1ldcat
St. Joseph Mi.
My first thought was the fuel cut off., but if it was that you should have to reset it if it actually triggared. Could just bump it enough to not have to reset. Hard to say and good luck.
Fullboogie
King of the Ski - OG Jr.
Houston
Fuel cutoff was my thought too. Easy to check - run a pressure gauge from the schrader fitting on the fuel rail, tape it to your windshield, and go for a ride. It may be the junkyard way of checking, but it works.
RRRoamer
I have data logged the fuel pressure during the stall event. It stays solid the whole time. And I have tried resetting the fuel cut off as well (in case it was making poor contact) with no change.
I might just bypass the thing for some testing just to make SURE it isn't a problem. Of course, how the fuel cut off switch could cause the vehicle security light to come on is beyond me. But then, fixing this problem has so far been beyond me too!
Big Top Gt
Coral Springs, Florida ~ 33076
Sounds like a bad IAC. (Idle Air Control motor)
It'll cause all of thise symptoms and I have to assume the 05+ Mustang has one. (I'm not as familliar with the 05+ as I am with the 04 and older.)
Actually, I think it's called the throttle control motor now.
RRRoamer
No, the 3Vs don't have IACs. The throttle control motor is COMPLETELY in control of the throttle blade.
But, it won't hurt to do some data logging on the throttle position sensor to see if there are any anomalies in the data.
marcspaz
~Resigned~
I have a co-worker who went through this with the exact same symptoms. It boiled down to a bad cam phaser on the right bank.
It was starting to come unsprung and everytime he hit a bump or something jarring happened, it would throw the timing way out of wack and the car would stall. Also, if he did any hard / high revs like from a hole-shot, as the rpms came down the car would stall.
It never showed any codes since the fingers on the phaser were not affected by the problem, so the computer never saw the issue.
It might be worth it to pop the covers and at least look at them. If you use a read sharpie to mark the chain and phaser and wedge the chain in the timing cover, one bolt pulls the phaser off. If you pull it and it pops apart or the pieces look cocked, its broken. Also, I am not sure what the inch pound tq resistance is supposed to be, but if you can find out, you can check the spring rate too.
http://iihs.net/fsm/?dir=165&viewfile=Camshaft%20Phaser%20and%20Sprocket.pdf
05stroker
Never enough power guy!
Bullard Tx.
The in lb spec per Livernois is 210 in lb but beware while this spec is used by them all the time I snapped the first bolt when torqueing the bolts so the mine are at 160 inlb right now.
Also when this happens and you turn the key back on is there any ticking noise comming from the throttle control actuator motor on the throtte body?
SteveP
Modular Specialist
Boynton Beach, FL
what about a short in your power cable? Might have gotten krimped somehow and the jolt of the bumps cause it to move and disconnect the wires.
Just a thought.
RRRoamer
marcspaz,
Very interesting. I don't remember having stalling issues after playing with redline, but I can DEFINITELY test that! ;) Would his car just flat out die like someone turned the key off, or would it hesitate and sputter before it died? Was his issue temperature sensitive as well?
05Stroker,
Thanks for the specs. As for a ticking sound, I have NO idea. Usually, I'm coasting down the road, so I couldn't hear any ticking sound from the TCA anyway. I also don't have to turn the key off. Just push in the clutch and turn the key to start. Heck, when I am rolling, I can just push the clutch in, wait for the rpm to drop to zero, then let the clutch out and it fires right up. No need to even TOUCH the key.
Skeeter,
One of the first things I did was data log the voltage going into the PCM from the two PCM relays. It was DEAD steady. Heck, during one data logging session, the voltage at the PCM had a MINIMUM of 13.85V and a MAX of 14.01V!!! I couldn't believe how tight the regulation of the alternator is!
The other indication that it is not a power/ground issue to the PCM is the fact that the PCM does NOT reset during the stall event. When ever it losses power, even for a split second, it resets and has to go through the whole power up routine, including lighting up the dash gauges... Nothing like that is happening on my car. The PCM either THINKS the engine has quit, or it INTENTIONALLY stopped the engine.
At this point, I am starting to think the problem might be in the active anti theft electronics. Due to the vehicle security icon lighting up and the way it flat dies. We have focused on PATS because of the PATS related P0689 and P0670 codes, but I don't think we have ever really looked at the ACTIVE alarm system and what it was capable of. Now I just have to figure out how the active alarm is interfaced to the PCM.
marcspaz
~Resigned~
marcspaz,
I don't recall if he mentioned sputter or not. I do remember he said it happened at random times and if he drove normal and didn't hit any jarring bumps, he could drive it normally without it stalling.
I will call him at work on Saturday afternoon and get specifics.
Every diagram you need is right here. http://iihs.net/fsm/?dir=40
I agree that the relay and other ignition kill parts would be a good thing to look at too.
RRRoamer
marcspaz,
Thanks! I would REALLY appreciate that!
MADMACS,
I can't directly data log spark, just the ignition timing and the signal going to the primary of the COPS. That would tell the tale as there is NO WAY that all eight COPS are developing the exact same miss at the exact same time.
While doing that, I should also check one of the fuel injectors too. If the PCM IS turning off the engine due to the security system, I would assume it would kill both spark and fuel at the same time.
marcspaz
~Resigned~
OK, my buddy said it would sputter, power would fade, then it would stall. Made no diff if the engine was warm or not.
ixtlan
Hooper, Utah
The Active AT system incorporates the Passive system also into it. It states in the manuals that the PATS will not disable a running car.
PATS is active only for a few seconds when the
vehicle is starting. It is not a PATS concern if the
vehicle stalls after it has been running for a
minimum of 3 seconds. PATS will not disable a
running vehicle.
The Active system adds the motion and incline sensing.
I would look at the key, although I dont think it would affect the running vehicle regardless.
All the alarm systems go through the Smart Junction box. (Under Passenger kick panel). Has anyone been done anything in the area?
Just a starting point to look at. Loose plug, something possibly?
solaratomic
Just a shot in the dark, but my 05 was having all kinds of eletrical ghosts when it rained. Water was leaking into the brain box connectors. Lights wouldn't cut off, car wouldn't start, Radio would work unless the clutch was pressed in, etc. Next time it rains it wouldn't hurt to pull the cover over the brain and check for water.
RRRoamer
That's generally not a problem here. I can't remember the last time it rained and my car sits in the garage all the time. Especially if it is raining. I can't say it hasn't been out in the rain, but it has been a LONG time ago.
I am thinking about pulling the SJB out just to reseat all the connectors on that damned thing and see if I can see any sings of water intrusion or corrosion.
Herknav
Devil's Advocate
Arkansas
Have you tried re-seating the fuses under the hood? I had a recent issue that was fixed this way (engine would die and I got the "check charging system" message; never any codes and it was intermittant).
