702rwhp on the CORN
SiriusB0neR
Just wanted to say thanks to Chris @ Blow By Racing for taking the time to tune my pos Turbo Mustang. Other quick thanks to the guys at JMS friday night for the help with there Boost a PUmp. And Mr ADAM at MODMAX for building me a pretty stout 5.0 stroker.
To wrap things up 14.2 PSI and 19degrees of timing, with fuel duty @ 72%.
This is all with a 67mm turbo,gt500 fuel pump setup,80lb injectors,stock rails,stock fuel line,KB BAS,JMS Boost a Pump
Little Cool down time then BAM BAM BAM i hit my 700rwhp goal
The guys at Blow By Racing are top notch people who made me PROUD today:hi:
The curve looks pretty steep with almost no power below 4K rpm. I assume this is not going to be driven on the street a lot?
SiriusB0neR
Shouldn't be a roll only on 530rwhp I ran 10.8 @ 129 with a 1.51, leaving off the 2step at 5,800 on 7lbs
If need be I can switch tunes and run the NOS tune to pick up my bottom end numbers quickly
When I go home I'll post up the build
But it's pretty much ModMax 5.0 stroker kit with every option, head hand ported valve job new bronze valve guides, Manley Tiatium spring,retainers and oversized valves. Then the basic FRPP manifold, FRPP t/b, a/c delete , Ati harmonic balancer , windage tray. And some other stuff
http://www.modmaxracing.com/product_p/99525350.htm
Sharad
Site Sponsor
Fort Myers, Florida
That's a whole bunch of power. Should be fun!
For comparison, UPR's 2010 GT made similar power and ran 9.90 @ 133. You definitely have 9-second potential with that much power. Yep, I'm jealous!
SteveP
Modular Specialist
Boynton Beach, FL
Was a good time this weekend bud. It was pretty cool to see the same hp between yours and mine but able to see the huge difference with pump and E85. Enjoy!!!!
