TPS 14" 4 Piston Brembo GT500 Big Brake System-FREE SHIPPING!!
tpsmak
Brake System-$999 FREE SHIPPING!
Click here to order
http://www.tpsmotorsports.com/tps-14-4-piston-brembo-gt500-big-brake-system-2005-2012-mustang.html
Are you looking for a GREAT Brake upgrade for your 2005-2012 Mustang? TPS has put together a great package that will give you ALL the braking power AND MORE of the GT500!
Upgrade your S197's front brakes with the massive TPS 4-piston Brembo kit and get the confidence you need to dive into the corners at ultra high speeds. Brembo makes braking systems used by the top race teams and manufacturers in the world, including Ford Racing.
This bolt-on upgrade kit includes GT500 4-piston calipers, street pads, your choice of zinc coated rotors (slotted, cross drilled/ slotted, slotted/ dimpled), and braided DOT-approved stainless steel brake lines (optional).
This great brake upgrade kit is designed for all ABS-equipped 2005+ Mustangs, including the V6, GT, Bullitt, and GT500. Will not fit non-ABS equipped Mustangs. Requires 18" or larger rims for proper clearance.
tpsmak
I just negotiated a special promotion with my finance company and am offering a Special Promotional Price w/ 1 year 0% Financing Till the end of the month! Now you can get what you want, install it, use it, and pay for it in a year without ANY penalty!
tpsmak
Bump for one of the best upgrades you can get for your Mustang!
0% Financing available for up to 1 year!
tpsmak
Bump...These are the best bang for the buck brakes around for your S197 :clap:
B1GB1UE
Does this package fit the stock '11 GT/CS wheels if needed?
tpsmak
This kit is the same size as the Ford Racing kit.. I am unsure about fitmit on the 2011 wheels. If the GT/CS has the 14" Brembo Option then this kit will work fine.
