Stealth dual crankcase breather kit
JeremyH
3V Fuel Guru
Virginia Beach
Go stealth! This kit takes the guess work out of finding the right size breathers for your valve covers! They fit perfect and install in minutes while keeping a very clean and stealthy appearance in the engine bay. Breathers feature aluminum top and bottom caps with stealthy black anodized finish, stainless steel mesh and a dry high flow synthetic filter material that is washable and reusable. The bottom rubber mounts are also removable for easy cleaning. I have been running these on my car for a few months now and they work great to relieve crankcase pressure while keeping oil out of the engine bay even at 18psi.
$25 with free shipping in the cont us!
(The filter mesh is really darker grey/more black looking as you can see in the second pic without the flash)
Wicked One
westchester NY
This is a great thing, but can I have the dimensions. The height of the passenger side. I have a custom intake and want to make sure I have the room. Thanks Jeremy.
Sent from my EVO using Tapatalk 2
JeremyH
3V Fuel Guru
Virginia Beach
Would I need a breather for the oil filler tube as well if I ran these?
Depends on your setup. For a turbo car I reccommend it but its not required.
what motor?
Sent from my SGH-T989 using Tapatalk 2
For the 3v I can do sizes for any vehicle though.
No more catch can for me send me a pm.
On the way.
Sure thing.
Should the PCV valve in the driver side valve cover be removed when using these?
I have seen it cut out from underneath the valve cover by a few guys. I still have mine in and its vents fine. One of those things that wouldn't hurt either way.
06stinger
Can these be in place of catch cans or should I be using both for a turbo set up?
BMR Tech
Traction Vendor
Tampa, FL
Great pieces.
I use the same ones on my 850 HP Cobra, except, the element is black. ;)
